I keep getting BSOD about IRQl nOT less or equal or some jibberish Wiped computer didnt work tried vista didnt work-went back to xp didnt work
Steps To Fix IRQL not less or equal Windows 10:-
Steps To IRQL_not_less_or_equal Windows 10 fix. :-
Step 1: Rolling back the Drivers
Initially, go to the Control Panel at that point click on System Icon. At that point look for the System Properties Icon. The following stage is to tap on the Hardware tab and Device Manager to find the gadgets which are introduced in the framework. When you think that its, double tap on it. Tap on the driver tab and the rollback driver caught.
Step 2: Perform a System Restore Process
This progression manages the System Restore. Experience the focuses offered underneath to start the reestablish framework process.
Hold the Windows and R catch together to open the Run box. At that point type "rstrui.exe" in the content field in the exchange box and snap on "alright."
The System Restore window will open up. Snap on the "Following" symbol which will show in the window.
After this, select the reestablish point which was made before when the mistake was caused. Snap on the "following" catch.
Presently adhere to the on-screen guidelines to wrap up the System Restore process.
At long last, restart your PC for the progressions to produce results.
Step 3: Disable Memory Cache Process
For crippling the Memory Cache, press F2 key to enter the BIOS mode. From that point onward, explore through the BIOS mode and cripple the "Memory Caching" highlight.
Step 4: Remove the PC Malware
To play out this undertaking, you require antivirus programming in the framework. The counter infection programming will lead to the full output of the framework and expel the unsafe malware from the PC. Later on, the Anti-infection will reboot the PC. When the sweep is done, you will have the IRQL_not_less_or_equal Windows 10 fix.
For More Assistance or Help Realated to Printer Support Visit on Given Link:
https://www.acersupport247.com/blog/irql_not_less_or_equal-in-windows-10
Irql not less or equal sounds like a graphics driver problem. All you needed to do was boot up in safe mode and remove the gfx driver and the OS would have rebooted with the default driver and then you could have reinstalled it
sorry i posted it in the wrong section
it is for pc
