1997 Saturn SL Logo
Posted on Oct 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing outer tie rod ends
I need to see a diagram if possible on how to change outer tie rods on a 97 saturn sl1. i'm a widow of 2 girls. but i've done little things on cars before, so i think if i can see it , i can do it.(maybe)
Marvin
Level 3:
Top Expert:
  • Saturn Master 85,242 Answers
  • Posted on Nov 03, 2008
Marvin
Saturn Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29056633
Points
266281
Undue the lock nut and just screw them off, of course disconnect them from the steering knuckle 1st with a puller.
Change power steering pump
Play in the steering wheel is likely from worn tie rod ends. Have your inner and outer tie rods checked. The outer tie rods are connected to the rod ends coming out of the rack on each side, and are connected to the wheels. The inner tie rods are not visible-but are on the rods under the protective boots on each end of the rack and pinion assembly.
You may need a new rack assembly, but first check if you just need new tie rods.
1helpful
Have anyone out there ever change inner tie rods on a1995 honda odyssey?,if so simply explain,THANKS
Procedure on replacing the inner tie rod ends:
1) Raise and safely support the vehicle.
2) Remove the front wheel/tire assembly.
3) Clean the steering rod between the steering boot and outer tie rod end lock nut with a suitable penetrating lubricant and a clean cloth or shop towel.
4) Loosen the outer tie rod end locking nut 1/8 turn.
5) Loosen the steering boot clamp(s), and slide the small clamp off the boot.
6) Carefully loosen the boot and slide outward off the steering rack and onto the shaft to expose the inner steering rod mounting fastener.
7) If necessary, position the inner steering rack shaft in or out to allow for additional access.
8) Relieve the steering rod nut locking tab from the inner steering rack shaft, then loosen the steering rod ball socket nut 1 turn.
9) Matchmark the tie rod end to the threaded shaft.
10) Remove the cotter key and castle nut from the outer tie rod end threaded spindle, and using a tie rod end removal tool, remove the tie rod from the steering knuckle.
11) Hold the tie rod with a wrench, and remove the outer tie rod end from the threaded rod, counting the number of complete turns it takes to remove the tie rod end from the shaft. Write the number of turns on a piece of note paper.
12) Remove the tie rod end lock nut from the threaded steering shaft.
13) Slide the steering rack boot off the shaft.
14) Remove the inner steering rod ball socket nut from the inner steering rack shaft.
To install:
1) Inspect the tie rod end for looseness, and the steering rack boot and tie rod end boot for cracks deterioration or damage and replace as necessary.
2) Clean steering rack shaft and apply a light coating of Genuine Honda Power steering fluid as necessary.
3) Apply a medium strength locking agent to the threads where the inner steering rod ball socket mounts. Use a new locking washer and a new stop washer, and install the inner tie rod onto the steering rack shaft.
4) Tighten the inner tie rod end fastener by 58 ft. lbs. (78 Nm)
5) Peen the lock washer over the nut or onto the flat surface of the steering rack shaft.
6) Apply silicone grease to the outer circumference of the inner tie rod end ball socket, and onto the groove just outside of the socket.
7) Apply silicone grease to the inside of the small end of the steering rack boot, and slide the boot over the steering shaft and onto the rack and install the boot clamps. If the boot has air hose fittings make sure they are installed as removed.
8) Apply a light film of an anti-seize compound onto the threaded tie rod end, and install the tie rod end lock nut.
9) Install the tie rod end onto the tie rod, turning it in exactly the number of turns it took to remove it.
10) Install the tie rod end following the tie rod end installation procedure.
11) The balance of installation is the reverse of the removal procedure.
12) Check the front end alignment and adjust as necessary.
3helpful
Inner tie rod removal
The first step in replacing the inner tie rod is to remove the tie rod end. It's basically a three step process, where you start by loosening the jam nut that's used to set the alignment (toe-in or toe-out). That jam nut determines how far up the inner tie rod the tie rod end is fixed. The tie rod end is hollow and threaded, so it can be screwed on or off the inner tie rod. Any procedure for removing a tie rod will start by telling you to count the turns you unscrew the tie rod end, something that I didn't do, and I'll save the explanation for the end:-) After you loosen the jam nut, you remove the cotter pin from the post on the outer tie rod ball joint, and unscrew the nut that holds the ball joint into the tapered fitting on the steering knuckle (video to right). After you pop the outer tie end free of the steering knuckle, you can unscrew the tie rod end. from the inner tie rod, but you need to grip it with something. Inner tie rods normally have some flat surfaces or a splined surface for grabbing with pliers. In this case, I needed two pairs of visegrips and a clamp to hold the visegrips on the inner tie rod from moving in order to get the outer tie rod end broken free and turning easy. That video is below. I happen to own the shop manuals for my Dodge Omni, so I was able to study the procedure for replacing the inner tie rod in detail. I didn't follow it for a couple reason. First, they show my type of power steering rack (Saginaw vs TRW) needs to be removed from the car to change the inner tie rod. That's a lot of extra work, not to mention the fact I buried one of the crossmember bolts in my unibody and flooring repair! So I went with an inner tie rod removal kit from Harbor Freight, manufactured by U.S. General (in Taiwan). The tool is very simple, basically a large steel tub with a snap in opening for a large crows foot insert on one end and a 1/2" socket drive on the other end. The kit is shown in the photo to the lower left (which I need to replace), and a video of the procedure is shown below. The kit wasn't quite right for my car, I had to use an oversized crows foot and the ball joint housing on the inner tie rod was too long, so the flats on the housing were barely held with the crows foot positioned by hand at the very end of the tool. But I got it out.
How do i loosen the outer tie rod end to remove it from the bushing once tie rod is out of streeing knuckle i know it will need to be aligined and i need to count treads when putting new outer tie rod end...
You may need a propane torch to heat up the nut on end of outer tie rod. With tie rod still attached to steering knuckle try to loosen the outer tie rod end nut that is connected to inner tie rod. Pull tie rod end back out of knuckle. Use pliers or vise grips to hold inner tie rod end while turning outer tie rod end to the left.
97 a toyota camry do they have replacable inner tie rod ends
they do have replaceable inner and outer tie rod ends, although I do recommend replacing the entire rack and pinion!! Hopefully this helps!!
Impact bent the right front tie rod. how can it be removed for straightening or replacing?
First loosen the jam nut with a 21mm wrench. Then use vise grips or whatever you have to make sure the rod can be turned that goes into the outer tie rod. Then remove the cotter pin and 17mm castle nut. Strike the hub where the tie rod goes through with a hammer repeatedly until the tie rod pops out of the hole.
Then simply unscrew the tie rod end and replace it. If the inner tie rod end is also damaged, or the rod is damaged you will need to replace them as well. Inner tie rods have a special tool to remove them, see your local auto parts store.
Remember, replacing an outer tie rod end changes your cars toe (alignment). You will require an alignment after replacing it, even if you think the car drives straight.
How do you change outer tierod ends on a 1996 dodge grand caravan
jack vehicle up in front and make sure its secure. remove front wheels. tie rod is bolted thru steering knuckle. remove the cotter pin from tie rod end. remove the nut from tie rod end. use a small ball joint splitter and small sledge to release tie rod end from knuckle. if you dot have splitter a good hard hit with small sledge on steering knuckle where tie rod attaches will usually release it. b careful not to bend backing plate. loosen the lock nut on tie rod and spin old end off. try to install new end as close as possible to same position as old end. you will need a front alignment after replacement.
3helpful
Need torque spec for 2000 Cirrus outer tie rod ends
45 Ft-lbs Tie-rod balljoint stud-to-steering knuckle nut, and 55 Ft-lbs Tie-rod (outer)- to- inner jam lock nut
6helpful
4answers
2001 Dodge Caravan outer tie rod how to install it macking noice and shold i change stiblizar too
loosen nut on tie rod..22mm wrench,remove nut from tie rod end..18mm socket,hit side of knuckle with hammer to seperate tie rod end..unscrew tie rod end from tie rod..reverse procedure to install..you will to hold down on tie rod end to keep stud from spinning
1helpful
I need to replace the inner tie rods on my 97' conti......need a diagram of how to and any other info pertinent to the job - Bair
If this is a rack and pinion type steering, in order to remove the inner tie rods you will first have loosen the jam nut at the outer tie rod end,next unbolt the outer tie rod from the steering knuckle, unscrew the outer tie rod end off (be sure to count how many turns to remove), next remove the inner bellows boot (black boot) from the tie rod / rack and pinion, next is to unscrew the inner tie rod from the rack assembly (the do make a tool for this to make it easier) but if you do not have the tool,you can sometimes use a big pair of channel locks or a big enough wrench to fit on the fitting on the inside of the inner tie rod, and just unscrew the inner tie rod (normal left=loosen, right=tighten). Hope this helps. Would also recommend having it aligned after you are finished.
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
