Question about Uniden 2 Camera Wireless Surveillance With 7" Color Lcd
Freezes on pc
When hooked up with USB cable to pc, keeps freezing after motion detected
  • 488 Answers
This is a USB driver issue.
Make sure you have correctly installed the usb video drivers which should have been supplied with the unit. Also make sure your operating system has been fully updated. If needs be, uninstall and then re-install the usb drivers and the software.
Posted on Feb 15, 2012
Chute does not stay in direction i want to blow snow also cable that controls height freezes
I take it that your chute has a handle that turns a gear to make your chute turn. My plastic gear holder broke off so I now turn the chute by hand to where I want it and hold it in place with a tie down then I spin it by hand when I want to go the other way and hook it on the other side of the blower. It's a pain that way but Being an old machine I can't get parts for it. To hook the tie down hooks I drilled small holes in the sides of the chute and onto the body of the blower. To keep the cables from freezing i pour a little bit of car anti freeze on the area it freezes. Don't put too much on.
Dec 14, 2017 | Garden
Dvd keeps freezing up
Its very common problem with dell laptops with DVD drive, after 3-4 yrs it keeps freezes up and stops working. Even mine is Inspiron 1564 and facing same problem.
BTW, what is your exact problem is it only freezing but detecting DVD? or not even detecting?
Oct 09, 2013 | Dell Inspiron 1501 Notebook
I am using an HP ProBook 4510s. My touch pad keeps freezing on me. Sometimes it will work for a few minutes and then freeze and sometimes the computer boots up with the message No Mouse detected. Any...
I have a 4510s and had this problem before.
Part of the problem was synaptics driver was freezing, Driver Synaptics software upgrade may help if that is part of your problem.
Have you opened the notebook to upgrade or remove the HDD for any reason?
If so, you should make sure the plastic of the palmrest (which houses the touchpad mouse) has been correctly fitted back in place. It may also help to remove the palmrest and ensure the flexible cable is correctly inserted in the ZIF connector.
I also notice there are some contact points from the PC to the underside of the trackpad, it may pay to clean those with metho to make sure the electrical connection is good.
Sep 09, 2010 | Computers & Internet
HP Officejet 6310 drivers will not install
When you install the printer wait till you are prompted to hook up the usb cable. If you hook it up sooner that is the problem. You can have the usb cable to printer but not to the computer. Then run your install disc and you should be fine.
Mar 01, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Computer freezes when usb cable from printer is
ive try that before, there is a virus on your computer, that detects the updates of your USB port, try to scan your computer,
Aug 08, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Desktop computor freezing
your desktop loaded to windows when it freeze? if not check your parallel cable or sata cable inside check also your dc power cable if properly inserted.
Feb 10, 2009 | Gateway GT5220 PC Desktop
Mini ipod freezing showing charger sign
restart your pc press del key in your keyboard,
go to setup usb settings disable usb 2.0 setting
Sep 15, 2007 | Apple iPod mini M9160LL/A MP3 Player
Uniden 2 Camera Wireless Surveillance With 7" Color Lcd Logo
200 people viewed this question
Top Uniden Home Security Experts
Lawrence Oravetz
john h
Corey Amundson
Corey Amundson
Level 1 Expert
Are you an Uniden Home Security Expert? Answer questions, earn points and help others
