We just installed this new tub and shower set and the pressure output is just a trickle. All other water pressure in the house is normal. Could this have anything to do with how far the cartridges are screwed in before the handles are installed?
When you installed the new tub faucet you probably turned off the water to that faucet of even the whole house. IF IT IS AN OLDER HOUSE, TURNING THE WATER OFF AND BACK ON CAN LOOSEN SOME DEBRIS IN THE WATER LINES THAT CAN FIND THEIR WAY TO YOUR NEW FAUCET. If there is a screen at the end of the water outlet it can be clogged with gunk. Uncrew the screen on the water outlet and clean. You may also want to flush out the hot and cold outlets by turning the water off, removing the cartigages and slowly let water flush them out. Then reassemble. Also when you have the tub handles out you can turn the hot and cold supply valves off and on a few times to loosen more debris if it exsists........Joe
i HAVE THE SAME PROBLEM , i DID WHAT YOU RECOMEND AND THE FLOW WITH OUT THE VALVE IS Ok BUT THE vALVE GIVE A LOT OF RESTRICTION OR IS A HIGH PRESSURE VALVES? hOW I CAN INCREASE THE FLOW BY THE VALVES
i HAVE THE SAME PROBLEM , i DID WHT YOU RECOMEND BUT STILL THE ISSUE WITH OUT THE VALVES THE FLOW IS VERY GOOD , tHE VALVES ARE FOR HIGH PRESSURE ? , HOW i CAN REDUCE THE RESTRICTION TO INCREASE THE FLOW IN THIS VALVES
can i modify the valves to increase the wather flow or reduce the restriction?
