SOURCE: how to reformat my sony vaio PCG-7L1M
yes if you have xp or me they will atomaticaly format for you ?when it comes up it will ask if you want to boot from cd or hard drive reboot from cd
SOURCE: Looking for the specification of the Sony Vaio PCG-8K2R
http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCGTR3AP&upd_id=1087&os_id=7
just click and download your driver
SOURCE: the fan of my sony vaio model pcg 3c2l stops
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
