The nettalk duo worked well intially with the router. At that time i had not set a password to the router. i disconnected the nettalk duo.i set apassword to the router and after 2 months when i connected the nettalk duo, it's red light is constantly on.there is no ring tone on phone
ANSWER : I have had the solid red light come on every so often. I would power cycle the nettalk and it would be find for a while, then go out again. The solution is to assign the nettalk device a STATIC IP that is outside of the range of ip addresses assigned by your router for DHCP.
Example, my linksys e1200 router by default assigns DHCP addresses starting at 192.168.1.100 and goes to 192.168.1.149. If you assign the mac address of the nettalk to an ip outside that range (that is not 192.168.1.1 because that is your router) like 192.168.1.20 it will solve this issue. whenever the nettalk connects to the router, it will always get 192.168.1.20, I think the nettalk can't handle getting different ip addresses from the DHCP server.
Then tTurn off the nettalk, then do a power cycle on your router.
SOURCE: random disconnects
I have had the same problem. A technician from Zyxel company advised me to change the firmware to the newer one. My firmware is V3.40(MV.3) dated 07/29/2005. I received a new firmware file by email. It's 2,7 Mb binary file. I havent done it yet because I need to be sure there's no other way. It's the last resort I'll take. Now I'm experienting with WAN settings. Make sure you have WAN backup set to DSL Link, Fail tolerance 2, Recovery Interval 30 secs, Timeout 3 secs, Traffic Redirect disabled (if you have dynamic IP addess; this is in case of adsl connection). Above mentioned settings help a lot but sometimes it still loses connection. I've heard Zyxel Prestige 2602 HW tends to disconnect from internet randomly.
SOURCE: Quick repetitive disconnects
try to upgrade the latest firmware for the router and that would fix this problem, if u have any other wireless device operating in the same frequency of your router, try to swich off your other devices and check, if still the same, replace the product..
SOURCE: D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
SOURCE: just connected router to clear network modem and
Hi, I also have the clear network and haven't had this issue. Did you hook it up per the instructions? You hook the ethernet cable from the clear modem to the phone modem and then hook an ethernet cable to your computer or router. I think it's important to hook up per their instructions, to the phone modem first. You should give them a call, they'll work with you and help you to install everything correctly.
SOURCE: Getting Disconnected
Either you hava an IP conflict (two devices use the same IP address eg printer/laptop/ ethernet adapter/ wlan card etc. etc.. Look at the device map and check all IP addresses, if in conflict: give another one manually. Ips like 192.168.1.1 can be changed by giving another number to the last "space" behind the point (192.168.1. (1-99). Every device must have a unique one. Vista normally does that but sometimles the IPs are preset andf cannot be changed by VISTA.
2nd possibility: You have an onboard "N/G" or "A" adapter and / or ethernat card and a USB or external WLan adapter, all activated in parallel. Makes the firewall go crazy, disconnects adapters constantly, which try to reconnect.Disdable all but one. Then enable one after the other to find the "impossible" combination or just use one.
do 30/30/30 hard reset in nettalk duo .Steps that you have to perform on nettalk device! 1. Disconnect all cable from deice turned off completelty . 2. Turn on by connecting power cable Now be care full with this 3. Use paper clip and put in that reset hole and have it hold tight for 30 secounds ,4 After 30 secounds without releasing reset button disconnect power cable (hold reset button for 30 secounds (do not release) ,after 30 secounds connect power cable with still holding reset button for another 30 secounds the release the reset button ,wait for another 1 minute (green and red light will constantly blink) ,then powered off , then connect all cable (Ethernet ,and phone RJ11), then powered on by connecting power cable, then wait for another 1 miniut ! Then you ll here phone ring (you've done it ) Enjoy
I tried accoring to your suggestion, but it goes back to solid red and every few seconds green will flash and red again
