My batteries do not last in the camera no matter how often I change them, there is no obvious reason for this and no flashing warnings on the screen.... please help?
SOURCE: Canon Powershot A540 Digital Camera
Also switching to Duracell Batteries helped us with this same situation.
SOURCE: canon Powesgit sd00 digital elph won't take photo
ssue:
The LCD/Electronic Viewfinder will not display an image or the image is distorted.
1.
Press display (DISP.) button to turn the display on
2.
If all troubleshooting has failed, please have your PowerShot A520 serviced
SOURCE: Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
SOURCE: Camera says "change batteries" even with new batteries
Hi, Has anyone resolved this issue yet, I have a powershot s2 IS with the same issue - i replace the batteries with brand new duracell's and it says replace batteries i reseat the batteries and it works for a few pics if im lucky then says replace batteries again - any help would be appreciated - Canon offers no solution.
SOURCE: Hi I have a Canon PowerShot A460 and normally do
Go into the menu and find "reset"...this will restore the original factory default settings and may solve your problem.
