The power and vga cables are properly connected and the power strip it's plugged into is turned on and producing power. Even with this, I am unable to turn my monitor on at all. I don't get a blinking power light, a quick image on the screen, nothing at all. If anyone has any ideas, I would be really grateful.
Hi, I heave the same monitor with the same problem, when I press the power on button I get the blue LED but black screen. I changed the inverter and then the power board itself and still the same result. I now assume that is the driver board, but I'm not really sure. Can someone give me hint before I spend another 20$...Please...
This usually indicates a failure in the power supply board. Here is a link to a repair kit for that board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=116
I hope that helps, if so please rate my solution.
BuddyMc
SOURCE: After installing Windows 7, my SamSung SyncMaster
Yes,Because Windows 7 is taking the higher amount of Ram.So the videos will be very poor and also system will be slow down.You must increase your Ram to 1 GB. (or) Use windows xp.
Thank u...
