On my glass shower door handles, one inside and one outside there are button like screws hold the shower handles on. If you look closely you will see a small hole in the edge of the button. This hole is used to turn the button screw. This is not an Allen set screw, but rather how you turn the button screw. Insert a small Allen wrench into the side hole and rotate the button screw (not the wrench which acts as a tightening bar) clockwise to tighten or counterclockwise to loosen.
SOURCE: how do you tighten or remove handle on a danze
Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
