I have had my Panasonic 32inch LCD TV about 18months. It will not turn on with the remote or the power button on the TV. I have unplugged it from the wall and plugged it in again but no change. The red led light on the lower left hand corner of the set is flashing intermittently.
I have a 42" plasma with the same problem! The panel buttons do not work, the volume is stuck on one level and the remote doesn't work. The LED light flashes 20 times when tv is turned off.
tv worked just fine turnned off next mornning tried to turn on tv but no power even manualy or with remote
My 32 lcd Panasonic is 15 months old. it has just started not coming on when you push in the "on" button. i have to re- push the button and hope that it starts.when it doesnt come on, there is a little red light at the bottom of the screen which flashes. it not a big worry at present as it only happens occasionally, but its only 15 months old ! luckly i have a 5 year warranty on it, but knowing my luck it will be not covered !!!
I believe I have the same problem. The tv is about 3 years old. When you try to turn it on, you get sound from whatever the last station that was on for a second or two, but no picture. Then no sound, the TV clicks twice like it is trying to turn on again, then nothing. The red led light on the bottom left hand corner on the front of tht tv just blinks continuously. To get the tv to work, you have to unplug it for a few seconds and that seems to re-set it. This problem started about 2 months ago and was intermittent. Now it happens about every third time I try to turn the tv on.
Does not turn on. Red LED flashes and then stop. Nothing will happen again until power cord is unplugged. LAst week unplugging the cord reset the TX and then allowed the TV to turn on.
