Hi Irishmist1.
How to Remove Mold and Mildew from Front Load Washing Machines Today...
or this.
https://www.angieslist.com/articles/how-remove-mildew-smells-front-load-washer.htm
or.
front load Frigidaire Washer musty smell Google Search
SOURCE: Our Clothes smell musty and the washer smells too
I checked the whirlpool web site and typed in "musty washer" for a search of the site. They gave directions on how to run a cleaning cycle on the machine (whether your washer has a special button for it or not) This REALLY helped my machine. They also had trouble shooting tips for keeping the musty smell away.
SOURCE: Musty smell in washer
We had the same smell. It was so bad you could smell it when you came into the house. We switched to powdered detergent and the smell went away. If you put your nose down by the rubber seal you can smell it a little, but I consider the problem fixed!
SOURCE: MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
I have the same problem with my machine. Also a frigidaire. After speaking with many repair people apparantly this is a common issue. With mine the gasket that seals around the door has separated completely from the machine and you can literally lift is away. If you pull it back you can run your finger along the metal of the machine and lift of soft black mold. I am in the midst of trying to get my machine replaced with another brand under warranty. This has actually caused severe allergic reactions to my family and took over 6 months to find.
SOURCE: How to get rid of smelly washing machine? Has a
Use a washer cleaner like Affresh, then use only one tablespoon of soap per load to prevent re-occurance.
