Use only option that comes up to recover. Wait and then as soon as you press record..... video management file is damaged recovery is required to record playback
SOURCE: video management problem
sounds like you need to "recover" the hard drive.
Only other option you can try is to reset the camera.
SOURCE: Broken video management file/ recording failure
Although the instructions don’t make it clear, it seems to be important that the camera is turned off before you connect or disconnect the USB cable. The instructions do mention that you should not delete or rename files on the camera except in the EXT_MOV folder. The camera’s firmware is apparently quite fragile about file names and the presence of the extra hidden folders that both the Windows and Macintosh operating systems create when you delete something.
SOURCE: JVC G-z-mg365bu video management file is broken
For broken files, everio will prompt you to recover once switched on. If you mean deleted by accident, you can use file recovery software like Final Data Enterprise and a lot more. Mostly can be recovered, sometimes 80% or 90% of your total recording. Good Luck
SOURCE: warning-- video management file is broken---
okay, try to format your hard drive, if unable to you will need to replace with identical zif HD, see youtube demo how to replace the hard drive, very easy but must be very careful, format after replacing.
SOURCE: I have a JVC GZ-MG330. Today I was recording, and
Do not be that worried, in this case you still have chance to get back those video chips and you may need video recovery software to help, here are some programs you may rely on. Both programs can also recover photo and music files.
Video Photo Recovery Software (for Windows)
Mac Video Photo Recovery Software (for Mac OS X)
Tips:
Take the memory card or stick out and connect to your computer via a card reader.
Before your videos are recovered, do not attempt to save more files to the JVC memory card or stick in case the original files(your videos) are overwritten.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
