The only items on your set that should need replacement would be both convergence IC IC801 and IC802 which are both STK392-570 and you will also need to change the two 5 Amp pico fuses which are F9A04 and F9A05 they are both % amp pico fuses. All parts are located on the center Board
on the front panel of the TV hold in the menu and the Device/input buttons both together for 5 seconds and the led should falsh a two digit code after releasing the two buttons. If it flashes two, then a pause then 2 more blinks. Its a 22 code and chances are its the Convergence ICs. If either one of the green picos F9A04 or F9A05 are open. ( no Resistance) Its definately the ICs which have blown
thank you very much
what about resistors?
also how can i check for error code for that tv
what is the button pushing process to get the resulting flashing code
you seem pretty smart a appreciate your help
thank you
