I installed Windows 7 this morning. the MotionEye of my notebook is not working, I need driver for this. may someone very noble help me....
There probably is not a driver specifically for Windows 7.
Usually you will have to use the one for Windows Vista.
Windows 7 is only a glorified version of Vista anyway.
Go here:Drivers
Select the Downloads tab, then select the operating system.
If you have 32 bit Win 7 then select the 32 bit Vista.
If you have home premium then select the same for Vista.
In the next drop down menu select Original Driver.
There is one for Vista called camera module driver
SOURCE: i need driver for sony vaio vgn-cs215j PC Notebook
You can go to this website:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCS215JP&SelectOS=42
Select the operating system as Windows 7 and the updated cam driver is there..
Testimonial: "camara finally worked ,.. tanks... is there any software that would make the capture button work again? ... "
SOURCE: need driver for sony vaio VGN-CR220E built in web cam, motion eye
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E
There u go, all availble files for Vaio VGN-CR220E and Vista
Good luck
SOURCE: I have down graded my SONY VAIO VGN-CR21Z/R to XP Professional
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFJ270
here u can download..
SOURCE: problem with sony vaio vgn-fz220e
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFZ220E#div_pos_5
Your drivers might be incorrect. I have rechecked them again. If they don't work properly, you must check with it's driver properties. If you think it's still not working properly then try VAIO Recovery Center or visit VAIO Help Desk.
SOURCE: Sony Vaio VGN-FE770G windows 7 upgrade problems
hello, try the link below;
ftp://download.sony.com/US/pc/TIDMSC-01424702-US.EXE
the driver above is for vista and should work with windows 7.
I hope this helps.
Kind regards,
Amar Sondhi
