Need user manual for noma thm405r thermostat
SOURCE: CAN I WIRE A 2 WIRE NOMA NON PROGRAMMABLE
To the best of my knowledge, Noma does not make a high voltage stat (M# would be more helpful). You most likely have a heating only stat that operates on 24VAC. Also, at that wattage, the wires on your thermostat would need to be a minimum of 12ga.
SOURCE: We replaced honeywell/newmac mercury thermostat
that the correct connection - bare wires touching or problem with new stat - is it set up correctly
Testimonial: "Thank you!!Model # is the 501M from UPM Marketing...Furnace stays on even when we disconnect the faceplate.Removed jumper-but should reconnect?"
SOURCE: i need a manual for a noma 5+1+1 thermostat
Hi, i am sorry to say, the operating manual comes with the thermostat. You have a 5 day-2 day programmable Stat. The best thing for you to do, is to take this info. with you to a hardware store, tell them you are having a problem programming it, I am just assuming that is the problem and they can pull a manual that is close and show you how to program it. 5 day is Mon - Fri, and 1-1 is for the 2 day weekend. They all are pretty much the same when programming. Noma is an aftermarket stat. Good Luck, Sincerely,
Shastalaker7
