Datalogic Heron D130 Handheld Barcode Scanner Logo
Posted on Feb 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows Vista Heron D130 7.31.84 Installation
Anonymous
Level 2:
Sergeant:
  • Expert 192 Answers
  • Posted on Feb 07, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
192
Questions
0
Helped
41962
Points
607
2 Related Answers
Anonymous
  • 944 Answers
  • Posted on Mar 22, 2007
SOURCE: Datalogic Heron D130 (Barcode Reader) Header setup
Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below: The extended Header/Terminator keys for Wedge Interface users can be customized by defining them through a simple keyboard setting procedure. For example, the Numeric Keypad keys can be set for use as Headers or Terminators by substituting the default extended keys using this procedure. The type of computer or terminal must be selected before activating the keyboard setting command. Press and release a key to set it. Some characters may require more than one key pressed simultaneously during normal use (refer to the manual of your PC or terminal for keyboard use). The exact sequence must be indicated to the reader in this case pressing and releasing the different keys. Example: If one has to press the "Shift" and "4" keys simultaneously on the keyboard to transmit the character "$" to the video, to set the "$", press and release "Shift" then press and release "4". Each pressed and released key must generate an acoustic signal on the reader, otherwise repress the key. Never press more than one key at the same time, even if this corresponds to the normal use of your keyboard. Press "Backspace" to correct a wrong key entry. In this case the reader emits 2 beeps. Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard setting procedure. "SHIFT" must be repressed for each character and cannot be substituted by "CAPS LOCK". Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page; http://www.datalogic.com/_vti_g2_dwnlDett.aspx?idCF=1&idC=44&rpstry=13_ Hope this helps :)
Anonymous
  • 10 Answers
  • Posted on Aug 04, 2009
SOURCE: How can i turn of the beep sound on a Datalogic
scan beeper off code on page 60 of this manual...
https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=90ACC1877
How to reformat a computer
Performing a Clean Installation of Windows Vista is the preferred installation method. An alternate method available is an "Upgrade" installation. I do not recommend upgrading. Too many things can go wrong with an upgrade and I have seen this many many times with all Windows operating systems over the years. A Clean Installation gives your system 'clean' file paths which will create a much faster and reliable installation.
The instructions below will apply to those that would like to:
Do a clean installation on a computer without an existing operating system.
Replace an existing operating system and replace it with Windows Vista.
Install Windows Vista on a separate partition.
Note: These instruction will work fine for both 32-bit or 64-bit versions of Windows Vista.
[Top]
<>Getting Ready to Install Vista:
I would recommend, even before purchasing Vista, that you check that all of your 'needed' hardware and software will function in the Vista environment. Download the Vista Upgrade Advisor to check your hardware. The Vista Upgrade Advisor will help you identify and possibly resolve any Vista compatibility issues that may exist in your computer system.
Be sure that you update all drivers (video card, monitor, sound card ...etc.) for all of your installed devices.
You will need to check with the software maker to find out if it is going to be compatible with Vista.
[Top]
<>Clean Install Over An Existing Operating System:
Before performing a clean installation of Windows Vista, be sure that you have backed up any data that you would like to keep. A clean installation of Vista will mean erasing all data and starting from scratch. Use your preferred backup method. If you need backup instructions for Windows XP, click the link below:
Manually Backup Windows XP
[Top]
<>Configure your BIOS to boot from the DVD:
When you insert your Windows Vista Installation DVD, it should automatically launch. If it doesn't launch, try restarting your system with the DVD inserted in the DVD drive. If it still won't launch, you will need to configure your BIOS to make your current installation boot from your DVD drive. To gain access to your systems BIOS you will need to refer to your particular systems operating instructions. However, most of the time, by pressing the F2 or the Delete (one or the other, not both) key repeatedly once your system boots to the "logo screen" will give you access to "Setup". Also, many systems have a boot menu that lists something like:
Press F12 for setup
If this is your case, simply press F12 when given that prompt. In any case, once you are in setup, configure your DVD drive to the top of the boot order. Save the change and exit setup.
[Top]
<>Begin your Clean Installation of Windows Vista:
Place the Windows Vista installation DVD in to your DVD drive, then reboot your system to allow the DVD to launch. At your first prompt, press any key to continue the process. Click Next and then click "Install Now" when prompted.
You will now be at the "Get important updates for installation" page. It is highly recommended (if you have an Internet connection at this point) to go ahead and install any available updates to ensure a successful installation. Once you've received the updates, click Next.
You will now be asked for your product key information. Your product key is located on your DVD case. Insert your 25 digit product key then click Next.
Now, you should be at the License Agreement screen. Feel free to read through the whole thing but it is going to take you quite awhile. You must "Accept" the licensing agreement to continue. Click Next once you're comfortable with the licensing agreement.
This next screen contains the main installation options. Select "Custom Install" (this is the correct option for a clean installation). Click Next.
Setup will now ask where you would like to install Windows Vista. You will see the available partitions on your system. You will need to select the "boot" partition (usually C:). If your boot partition has a previous version of Windows installed on it, you will want to delete this partition and the create a new boot partition. Create any additional partitions as desired, just be sure that each partition you create is formatted. Once you're done, click Next.
From here, the prompts may vary depending on your particular system. Just follow the on-screen prompts to install Vista to your systems configuration.
Once Windows Vista installs the necessary files to run, it will restart twice. It is important that you leave the installation disk in the DVD drive until the Windows Vista is completely installed. After the first restart, you will be asked to insert any Username and Password that you would like to use and a Name for your PC. Additionally, you will be asked for the following information:
Time and Date settings
Current Location (home or office)
After all of your information is successfully received, Vista will boot a second time. After it boots successfully, you can safely remove the Windows Vista installation DVD.
Congratulations! I hope that you get many years of enjoyment out of your new Windows Vista operating system!
Important!: Make sure that you install proper anti-virus and anti-spyware programs to protect your new Windows installation. See the article below for some recommendations:
Secure a New Computer
[Top]
<>After a Successful Installation:
When installing Windows Vista with another Windows operating system already installed. Vista will create a file called, Windows.old" on your boot drive. Once everything is running fine on your new Vista installation and you are sure that you have your old data already backed up, it is safe to delete the Windows.old file. This file could be nearly 30 gigabytes in size. Just do a simple search for this file then right click and delete it. You will, of course, need Administrator privileges to do so.
If you receive an error that; "you do not have sufficient permission" when deleting this folder, the reason may be that you need to take ownership of the file and its contents, here's how:
1. Right click the Windows.old file and then select Properties.
2. Select the Security tab.
3. Click the Advanced button.
4. Select the Owner tab.
5. Click on the Edit button.
6. Confirm at the UAC warning prompt
7. Select Change ownership.
tip
How to format a computer with windows vista.
<span> <p>To format your hard disk during Windows Vista installation, you'll need to start, or boot, your computer using the Windows Vista installation disc or USB flash drive.<br /> <ol> <li>Turn on your computer so that Windows starts normally, insert the Windows Vista installation disc, and then shut down your computer.<br /><br /></li> <li>Restart your computer.<br /><br /></li> <li>Press any key when prompted, and then follow the instructions that appear.<br /><br /></li> <li>On the <b>Install Windows</b> page, follow any instructions that are displayed, and then click <b>Install now</b>. <ul> <li>If the <b><a href="http://www.whitecanyon.com/how-to-format-computer.php#">Install Windows</a></b> page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see <a href="http://windows.microsoft.com/en-us/windows-vista/Start-Windows-from-a-CD-or-DVD">Start Windows from a CD or DVD</a>.</li></ul></li> <li>On the <b>Get important updates for installation</b> page, we recommend getting the latest updates to help ensure a successful installation and to help protect your computer against security threats. You will need an Internet connection to get installation updates.<br /><br /></li> <li>On the <b>Type your product key for activation</b> page, do one of the following: <ul> <li>If you are reinstalling Windows Vista, you should enter your product key now.</li> <li>If you are not reinstalling Windows Vista, you can skip this step.</li></ul></li> <li>On the <b>Please read the license terms</b> page, if you accept the license terms, click <b>I accept the license terms</b>.<br /><br /></li> <li>On the <b>Which type of installation do you want?</b> page, click <b>Custom</b>.<br /><br /></li> <li>On the <b>Where do you want to install Windows</b>? page, click <b>Drive options (advanced)</b>.<br /><br /></li> <li>Click the partition that you want to format and click <b>Format</b> <ul> <li>If you have more than one partition on this hard drive and want to get rid them to make one big drive again, then select a partition and click on the <b>Delete</b> option for each partition. Once you have deleted all of the partitions, select the <b>Unallocated Space</b> partition and click <b>Format</b></li></ul></li> <li>When you've finished formatting, click <b>Next</b>.<br /><br /></li> <li>Follow the instructions to finish installing Windows Vista, which include naming your computer and setting up an initial user account. <ul> <li>If you do not want to reinstall Windows Vista, you can cancel the installation at this point and keep your newly formatted drives.</li></ul></li></ol></span>
on Nov 23, 2010 • Computers & Internet
2answers
Heron's formula
Heron's formula is used to find the area of triangle when the length of all sides is known.
Formula:
Wont do automatic windows update
try to restart the pc and check if auto updates, if it does not then go to www.microsoft.com and search for windows update. You need to update the latest windows version of it and it will auto-update your pc from heron
Hii..I Am Having An Acer Aspire 5050...Well I Installed Windows Vista Ultimate On It But Originally It Was Windows Visa,Therefore,After Installing Windows Vista Ultimate I Tried To Upgrade The...
A solution to that is to install Windows Vista Ultimate on top of your old vista installation. Just insert your Vista DVD and restart your computer. And simply follow the instructions for the installation.
Cannot install windows vista ultimate 64 bit on my computer when I have xp installed. Can boot from the 32 bit version disk though but I want the 64 bit. Tried booting it from start-up by booting from CD...
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
    Note When you receive with the Get important updates for installation message, click Go Online.
  5. Click Upgrade when the Which type of installation do you want? screen appears.
    If you cannot click Upgrade and you receive an error message, go to the "Troubleshooting" section if you are comfortable trying to troubleshoot, or go to the "Next Steps" section to determine your next steps.
  6. Follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the upgrade to Windows Vista.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Perform a clean installation loadTOCNode(2, 'summary'); There are two ways to perform a clean installation of Windows Vista. The first method is to install Windows Vista by running the Setup program from the current version of Windows on your computer. The second method is to start the computer from the Windows Vista DVD. First, try method 1. If it does not work, try method 2.
Warning In a clean installation, existing data on your computer is deleted. This data includes personal data, settings, hardware driver information, and software programs. After you install the operating system, you must also reinstall all programs. Make sure that you back up personal data to disks or other external storage devices before you perform a clean installation. Method 1: Perform a clean installation of Windows Vista by running Setup from the current version of Windows loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Method 2: Perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD loadTOCNode(3, 'summary'); Note The computer must be configured to start from the DVD drive. For information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer. Or, contact the computer manufacturer.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Can I get a driver for this printer to operate with Windows Vista?
According to the Epson website, Vista is supported:
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
Top Datalogic Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
