I have checked the power cord. Good. Tested the pushbutton power switch. Good but still no red licht. Tested the 3 amp input fuse to power supply. Good. If I need a power supply where can I get it.
Hello
Eventhough the fuses and power cord os good, and there is no power light on the panel board, means the power board do not get power to it. Check an other power outlet point first. If it does not help you, soethnig wring with the power regulator baord. Normally, these board are irreparable, and replacement should be done as card basis. OK.
Testimonial: "I just got done checking all the outputs (didn't have a proper meter before) from the power board. You are absolutely correct...it's toast. Now I am trying to find out where to get one. It's Ironic that I live in Japan but have to search the US for the part. Even though it's a Hitachi, it is considered a foreign TV here based on the model number. Thanks."
No power
