Question about DeLonghi DE500 Dehumidifier
Delonghi Dehumidifier DE500P - Code E3
Hi Speedy,
I'm having the code E3 on my dehumidifier. I have called customer service and they adviced me to ship the unit to a service center which is about more than 3 hours drive from my house and the shipping cost was more than $100. The service center would not tell me what the code E3 means so I figured if I can just fix it myself.
Can you please tell me where you order the part and the part id so that I can just order and have the unit working agains. Thanks
  • Anonymous Oct 24, 2008
    Thanks Speedy for the information. will call to get the part. Thanks against.
  • 3 Answers
Hi Thomast5263,
I live in NJ and the nearest center is in CT. So you can imagine that I am not gonna to ship my unit! :-)
The one I got is from Hartford, CT Utility Electric Service: 860-246-7271; talk to Dana and he is very helpful. They charged me $25 and shipped me the part and it now works fine.
When I talked to Dana he sounded pretty sure it was the condensor sensor. Simply call Dana and tell him that you have an "E3" code. I do NOT know the part number or ID.
Don't open the unit until you get the new part ---- it will help you to identify the part to be replaced. After you get the part, make sure you mark down all the screws (they are not the same! so pay attention which one is where). There are two tabs on the top so be careful when get them separate apart ---- don't force it or you might break it. The sensor itself is attached/stuck in between the copper coils under a black cover. Plug another end to the control board and you are done. Apparently there are two kinds of plug-in end ---- the first part Dana shipped to me did not match the old part so he has to send me another one which worked.
The whole procedure is not that difficult, but when you are doing this the first time you just need to be patient to locate all the screws and sparate the covers. From my experience you do need to take all covers off, otherwise you can not see the part and the wire.
Good luck to you and let me know the good news!
Posted on Oct 23, 2008
  • 1 more comment
  • Susan Hutt Aug 11, 2011
    Am I going to get the same wrong part first? How do I get away from this?
    You may as well take your help ad out speedywheel, as I called today to get the part and they cannot do it any more, by law. I feel so bad, here I have a beautiful machine that is too heavy for me to even take to the dump - I can just see it now, mile after mile of Delohghi dehumidifiers that have parts that someone may be able to use. Too bad!!! Personally, I'm sick about it.
  • john Apr 26, 2013
    thutt i have answered this question already search for it and youll find it. there is a way to bypass this sensor and computer altogether, do not junk your unit!
6ya staff
SOURCE:
I have a De Longhi de500p. Runs and I can hear the compressor kicking on and run. But I am not getting any water in the tank. Room temp 75 degree and humid meter set at 40 .Please give me some advice
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 31, 2011 | DeLonghi DE500P Dehumidifier
E3 code...what to do? on dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can provide you with the Error Code solution, as well as email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
Jun 01, 2011 | DeLonghi DH40P Dehumidifier
Delonghi 500p freezes up at bottom left of coil and then does not dehumidify
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
May 29, 2011 | DeLonghi DE500P Dehumidifier
I have Delonghi DE500P dehumidifier was running but doesn't pump water. how can i fix it.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck
Aug 11, 2010 | DeLonghi DE500P Dehumidifier
Need instruction booklet
You can get the manual of the one that you have listed under on the link below. If it is not the right one please give us the make and model # so we may get you the right one.
http://www.sylvane.com/images/productpages/DeLonghi/Dehumidifiers/de400-de500-de400p-de500p.pdf
Good Luck and please rate 4 thumbs for the free answer
May 06, 2010 | DeLonghi DE500P Dehumidifier
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
DeLonghi dehummidifer de500p when i first plug it in comes on
DE500P does not run and shows error code E3. What part do I need to replace and where can I get it?
Mar 24, 2009 | DeLonghi DE500P Dehumidifier
Lost owners guide to delonghi dehumidifier de400p showing code of e3
I am searching for a resolution to the E3 code (same init) and happened upon this request. The manual can be downloaded from DeLonghi.com but that advises you to call the service center.
Tom C
Jun 04, 2008 | DeLonghi Dehumidifiers
De500p lost owners book
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
This should solve your problem.
May 05, 2008 | DeLonghi DE500P Dehumidifier
DeLonghi DE500 Dehumidifier Logo
1,558 people viewed this question
Top DeLonghi Dehumidifiers Experts
nm156
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
