I've got UPnP on so my NAT is open. I've tried using DMZ hosting but that hasn't helped. So I'm thinking it has to deal with my gateway because every 10-30 minutes i keep getting disconnected I'd appreciate it if there were some sort of self walk-through anyone has done that I could follow to make it where I don't get disconnected.
SOURCE: ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
SOURCE: I have an actiontec router
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is enabled
SOURCE: I've opened all the proper
only way i solved it was to go into advanced configuration and turn off firewall when i want to use it for gaming. specifically black ops.
