Can you tell me if by changing the software can i tranfer mp3 via bluetooth or tell me some other suggesition so that i can be able to tranfer mp3 form my LG RD 9800 because i have purchased it as a new phone thinking that it has bluetooth so that i can tranfer mp3 please just e-mail me at [email protected]
The phone may not have bluetooth capability for file transfering. You can try to go your song that you want to trasfer and click on more option to see if there is a tranfer button or icon for bluetooth. If it does not then the phone does not have the ability to do that. hope this helps.
I don't know whether its exactly the solution or not, but I had a similar problem transferring some mp3 files to any cell via bluetooth from my nokia 7210, I tried all combinations of bluetooth settings, but the same message kept appearing-"Sending failed", finally what I did was "Changing the name of the mp3 files" as all those I wanted to send had a bigger name, I cut the name short and there it worked. So, may be in any such case it's advisable to just try this out, it might just work.
When transfering dta from another phone by bluetooth it asks for the password usually 1-4 numbers to confirm authencity just enter 0 in your phone and 0 in the other phone when password is aksed for an easy solution . When you receive Mp3 or Video via bluetooth it's received a message and stored in your phone's main memory . Go to Messaging and setting and change default storage location to Memeory Card , don;t forget to copy all your messages when asked . Now you can utlizie the memory card for media received by bluetooth
yes you can select the BT make both visible on the phones, then you will select the mp3 you want to transfer then select options,send via, choose BT and you are good to go.
Use a bluetooth on your pc.If your pc did come with a bluetooth use an external usb blue tooth and sychronize your pc and phone via bluetooth and use the file tranfer on your bluetooth installed in the pc to transfer.
Most acer laptops have the bluetooth front button but very few have it installed.
No device means yours is not bluetooth enabled and you will have to purchase a usb bluetooth adapter, class 1 being a 10 metre distance connection, class 2 being a 30 metre connection distance.
