I have a 2005 Grand caravan 3.3 with 236.000 miles it came up with a code P2308 ignition coil C secondary circuit ? No spark to cylinder 6 & 3 ?
No cylinders fire at same time. 6 & 3 must be from same coil-ignition coil C-that is the one with the problem. And the secondary circuit- that is the spark firing portion of the coil. Coils have a primary winding circuit and a secondary wire winding circuit. The secondary comes out of coil as the tower, or the spark plug wire tower -the business end of the coil leading to the plug.
You could have a bad new coil (happens occasionally) or the connection to that coil may be the problem-the connection where the coil snaps onto the coil pack assembly. Try swapping that coil (coil C) with another one there and see if problem follows the coil. See? Keep your plug wires the same, just swap coils with another and see if the new position for suspect coil causes other cylinders to misfire. If a different coil in that "C" position causes same code, then it is not the coil itself, but probably the base assembly that the coil connects to.
These ignition systems use what is called a waste spark, or exhaust waste spark system. The coil will send spark to 6 & 3 simultaneously, but since one is always on the exhaust stroke while the other is on the compression (firing) stroke, the exhaust spark is very weak, and all the energy from coil is directed to the compression stroke cylinder. It sounds crazy but it works great.
Since you say it runs bad just as before, that indicates the coil is not the problem, but something wrong with the base of the coil pack . This is where the wiring is directed to the coils.
thanks
what is freon?
Freon is the gas/liquid that comes in super cold and pulls the heat from the house. As it goes through the a-coil the fan blows across it making the air cold. It exits the coil and returns to the outside unit.
