Hi, I've misplaced the operation manual and wanted to change a few settings on the phone. could someone pl assist me to obtain a pdf of the operation manual? thanks
go google and type in--- user manual for samsung galaxy 3 mobile phone --- there is a pdf version that you can down load and that will show you how to set what you want
I bought a cheap digital humidistat at Walmart to keep an eye on the humidity in my basement. I hung it on the wall not too near my dehumidifier. I have found that the settings on the dehumidifier are misleading, but I found a setting that keeps my humidity between 40% and 55% (at around 70 degrees), as measured by the humidistat.
Since you neglected to specify the model of your VTech 5.8GHz phone, I can only direct you to enter it into the search box here to download a copy of the manual.
Take a look at your watch. While
models and brands vary, you'll find a few things in common on almost
all of them. First, they'll have different modes of operation. A typical
digital watch may have modes for time, stopwatch, date, alarm and
timer, to name a few. Look on your watch for a button labeled "mode."
Press it several times to see what's available. Typically the watch will
display the name of each mode as you push the button repeatedly. When
you've found the mode you want to adjust, stop there.
Look for a button that is
labeled "set" or "adjust" on your watch. The location will vary,
depending on the brand of watch you own. Press in and hold this button.
After a few seconds, the time (or whatever mode) you have selected will
begin to flash. In most cases, you'll need to select the item you want
to adjust (minutes or hours) by pressing "mode" again. Once the portion
you want is flashing, you're ready to adjust it.
Press a button to advance the
parameter (hours or minutes) that you've selected. This button may or
may not be labeled. If it isn't labeled, you'll have to experiment with
different buttons. Once you've set the first parameter, change to the
second by pressing "mode." Follow the same routine to adjust. To exit,
you'll typically press the "set" button.
Use resources available to you.
There are thousands of digital watch styles on the market, each with
slightly different setting methods. When you buy a watch, tuck the
manual away in a safe location for reference. If you don't have the
manual, do a website search. Most major manufacturers keep their manuals
online for easy future reference.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDS50A2020&LOC=3 are the operation instructions incase you lost or misplaced your owners manual. here are the entire operation instructionds including the lamp chanbe directions and where to get a direct replacement lamp. but i would first look at the several lamp suppliers that are listed here on this web-site, good luck Larry Dillon AKA techman
