Twelve minutes into the cycle it just started beeping. The display was flashing between H and F. I tried to turn it off with no luck. I can't get the door to unlock. I tried killing all power to the unit twice but that didn't help. What does the error code mean? How do I get the door unlocked?
SOURCE: Whirlpool Duet Washer
F11 is a serial communications error. This is a symptom of an electronic control board starting to go bad. As defined by the technical information provided by Whirlpool, the error could also be caused by a loose or broken wire connector and/or the central control unit (CCU) (front panel). I would double check all your wire connections leading to the control board and CCU, first. Don't be surprised, however, if the problem persists and you eventually have to replace the electronic control board. To check, follow these steps: 1. Unplug washer. 2. Remove the three screws along the top of the washer in the rear that holds the top panel on. 3. Once the screws are removed the top should slide back then lift up. 4. The electronic control board is gray (or white) in color and located in the rear of the washer. It's impossible to miss. Double check all the connections ONE AT A TIME. 5. Double check the wire harness connections leading to the front panel as well. I hope this resolves your problem, but experience has proven that this is usually an Electronic Control Board failure. It could actually be a combination of the CCU as well. The part numbers are as follows: Electronic Control Board: 959503 Central Control Unit: 1025824 Both boards cost about $150 each. Let me know if this helps you.
SOURCE: Whirlpool Duet Washer-error code "sud"
The SUD message relates to overdose of detergent detected during the Wash Cycle. This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds. If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked. Good luck
SOURCE: whirlpool duet washer
this is all i can find for you hope its usefull
“F” Variables [other than FH, F02, and SUD] (Electrical
Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
"F11" is a serial communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU), or interconnecting wiring. In a nutshell, the CCU, (which is the main computer board for the washer) has more than likely failed. You can try disconnecting the connectors and plugging them back in on the CCU, but I haven't had much luck with that remedy. You will need to UNPLUG the washer & take the washer top off by removing the three screws in the back to gain access to it. Once removed, slide the top back and then lift up. The CCU is located directly behind the wash tub.
If you cannot get the fault to clear and wish to repair this yourself, you can find the part at repairclinic.com. Just type in your complete model number and look for item number 1176592. The part lists for about $157. Searspartsdirect.com also has the part for much more, but offers informative troubleshooting diagrams. The CCU can be found under the "Control Panel Parts" heading as item number 15 (part #8182695). If you wish to do some comparative pricing of your own, use the part number provided by the Sears website.
If the washer still carries a warranty, this would be covered. Doublecheck with the manufacturer on how long some parts are covered. Some of the electronics and mechanical parts are covered beyond the one-year limited warranty that generally comes with your appliance.
I know this may be discouraging news, but you can repair this yourself and avoid labor costs. It may seem expensive, but considering how much these washers cost (I know, because I own one), it may be worth the effort. I hope this helps you. Post back if you have further questions or need instructions.
SOURCE: whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• cleaning a drain pump Check drain pump for foreign objects
• If the above does not correct the problem replace the pump
