Lost/misplaced newly purchased cd-rom for dmc-zs10. Can the software be downloaded from Panasonic? Serial Number FB1GC008617 purchased NOV 21, 2011 from Costco.
SOURCE: cd-rom for dmc-fz50
I will try to find my copy & make you a copy if you want.
regards,
1deaddog
SOURCE: DMC-zs10 records on internal memory
Hello bro..
Do you check your SD card? It is work ?
My solution:
1. Off Lumix camera.Until LCD was off. Press center of card to remove it.
2. Use card reader to connect your SD card to pc/netbook/laptop..
3. Check full capacity for SD card, it is empty(zero) or have it their mount.
4. If empty (full,used,free is zero) ,try reinsert card again and don' t touch the terminal.
5. If still empty, that mean, your SD card was corrupted.
6. If not empty, backup all data in SD card.
7. Format the SD card using FAT32.
8. Checking Disk.
9.Insert back to camera, and format SD card using camera menu.
10. Take picture. and see if save on SD card or not. comment back here. if succes or not.
11. Don't use any battery except original from panasonic. It will affected to product.
12. Don't remove battery or card before lcd was off light.
SOURCE: I need a User's Manual
You can download the manual for free in the following link:
http://www.retrevo.com/support/Panasonic-DMC-ZS10-Digital-Cameras-manual/id/23893bh841/t/2/
Hope this one solved your problem. If you have additional doubts, please come back to us.
P.S: If the solution is helpful, please accept the solution.
Regards,Sunny.
