SOURCE: AL 1716 LCD monitor has no power when plugged in.
lg LG M1717S lcd moniter no power , what is broblems and solution please,
thanks
As someone suggested the 3 10 volt 1000uF caps are bad. You can
indentify them because they're puffed up on the top and therefore
blown. Replace them withj a 25 volt cap 470uF or larger and away
you go. I did 4 of them in 3 hours. The case snaps apart
which is the hardest part. them remove all the screws you
can find, unplug the display from the board, remove the rest of the
screws holding the power supply board down, and look for the puffy
caps. Cahnge them and put everything back together and away you
go.
Richard
SOURCE: Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
SOURCE: ACER LCD monitor has no power.
It is probably the inverter which powers the backlight. It should say inverter right on it.
SOURCE: Acer AL2216W's green light goes off completely
You may have failure in the power supply due to bad caps, bad inverter circuits such as shorted transistors, transformers, bad lamps. You need to open it up and make some measurement, see example of failed ACER monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
umm a vga cable would be preferable for testing purpose but let us know the results of that please
