D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Logo
A
Anonymous Posted on May 18, 2017
I can't open the dlinkap for the D-Link DAP 1522
I've just purchase a D-Link DAP 1522 to use as a bridge between my Mac and Xbox but I am unable to successfully load the config page. I enter the IP 192.168.0.50 into the URL and it loads, however the page is just black and orange and is covered in 'Related Searches' and I can't actually find the Setup Wizard to link the bridge to my router (My router is a normal D-Link one supplied by Sky, unable to find the exact model at the moment) Please help! I don't want to have just wasted £80!
2 Related Answers
Anonymous
  • Posted on Aug 31, 2009
SOURCE: dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Anonymous
  • 610 Answers
  • Posted on Mar 24, 2011
SOURCE: I just got a dap-1360
just make sure that you belong with in the same IP range.
default DAP-1360 IP is 192.168.0.50
username : admin password :
change your PC IP address to 192.168.0.xxx (e.g. 192.168.0.2)
from there you may choose wizard or manual configuration.
you may change your DAP-1360 IP add according to your network settings in the office and you must change you PC IP address with in the same range.
How to assign static IP of my access point DAP 1150 to my pc
From your computer, get the MAC-address of your network adapter.
Configure the router to always give out the same IP-address for that MAC-address.
2answers
How to reset dlinkap 1320
Hey Rolando,
On the back of the unit is a small button to reset. Use a straigtened paperclip to do so. Attached is an image of what it should look like. b86d4bfe-0100-4d89-87bc-74360b9790d9.jpg
If the page does not open then you don't have a connection to the router. Make sure your cable is attached to the router and computer. You can't do the initial install wireless usually.
JE NE PEUX PAS INSTALER DAP 1360
Access D-Link's support-site: ftp://ftp2.dlink.com/PRODUCTS/DAP-1360/
Choose 'REV. A' or 'REV. B' or 'REV.C'.
Download the instructions for your router.
2helpful
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1360
Connect your computer to the router.
Assuming Windows 7, click the "Start" button.
Into the search-box, type 'CMD' and press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Dlinkap
You can do a reset to default settings. OR using the on-line setup, change/remove Security Key, refer to the User Manual here: http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201522/Manual/DAP%201522_Manual_EN_US.pdf
Dap 1320 can't set it up using web browser link
These answers on all these sites are very confusing. Here's what I did to solve the issue of not connecting with a browser. 192.168.0.50 does not work nor does http://dlinkap.local. or whatever else is printed on the device. On my PC that is hard wired to my router, I logged into my router, checked which wireless devices were connected and found that dlinkap (note this is not the SSID that is printed on the device) was assigned 192.168.0.4. Set my browser to 192.168.0.4 and off we go to configure the extender.
Cant open the link to setup the router
Refer to page 3 of the Quick Install Guide listed on the web site below.
There are multiple ways to configure this router and do not wish to provide HOW TO without knowing how you have it set-up.
www.dlink.com/products/default.aspx?pid=DAP-1522&tab=3
13helpful
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1522 up as a wireless bridge. My current internet provider is Verizon Fios using their router. Why can't I...
Maybe you have the wrong 192... Go command prompt and type in "ipconfig" without the quotes. scroll up and find the default gateway (default gate way . . . : 192...) and type that in your browser and press enter.
If that doesn't work, go to your network connections and right click on the one that is connected click properties, click on Internet Protocol Version 4, click properties, and make sure all the settings are automatic. Restart computer, repeat first part.
If that doesn't work, reset your router and access point. Than reconnect and repeat first part.
1helpful
Dlink dap 1522
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
