I installed a brand new cartridge but keep getting the message to replace the empty cartridge to resume printing. Printer will not print - not even in black. Any ideas how to correct this problem
Follow the steps below to remove and replace the empty ink cartridge.
NOTE:
Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
NOTE:
Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted.
Figure 4: InsertNew Cartridge error message - c00819083.gifrtridge
NOTE:
All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
after Doing this all Follow the next step :-
Please Try This, I aNew Cartridge error message - fa37665.gifs going to workout.
Resetting the All-in-One
Press the On () button to turn off the unit.
SOURCE: Empty ink cartridge message
I replaced the old cartridge with a new one (Magenta) and it still asks me to replace it with a new cartridge.
For 1 colour which is LOW, it stopped me completely from PRINTING or COPYING at all.
Any clues how to fix this?
SOURCE: cannot print in black because yellow cartridge is empty ?
Take the "empty" cartridge out and shake it, and then reinsert it. I did that on my HP 8500 and it worked. The indicator light showed it was full.
I installed a new cartridge 2 times but each time the printer is telling me it's an empty cartridge .I know the cartridge is not empty but don't know why the printer thinks it is. I reset the printer and cleaned the cartridge heads. No luck.
I replaced the cyan blue ink cartridge twice and it keeps telling me to replace it.
My yellow keeps reading as empty and needs to be replaced. I have replaced it four time with a new HP Genuine cartridge and the message to replace continues!!!
Same problem with the yellow cartridge on my C5180. Called Tech Support and was told it's a hardware problem. I bought the machine "refurbed" at Officemax 6 months ago.
Exactly the same problem with the yellow cartridge, has anyone found any sort of solution?
Same as everyone else, just change out the color for magenta, any clues?
Same problem with the yellow ink.
yellow ink also....argh!!!!
same problem with the Yellow Cartridge.
Same problem. Yellow cartridge is not empty but the printer said so.
And another problem i have is a error message: 0xc18a0306.
I also have the same problem with the yellow
i have same and its so frustration i've change thje light magentat 4 times and and is now not happy. i am cluess?
