Universal Remote Control NspireGear MP3 Player Logo
Posted on Oct 21, 2008
Need to program rca universal remote for symphonic tv model SC313E
Have tv/vcr combo Symphonic model SC313E  aand have rca universal remote..need to find code to program tv
  • Anonymous Mar 21, 2014
    program code for rca tv model rlc3956a
A
Anonymous
Find code for symphonic tv remote
very few if any universal remotes will work on Symphonic which is also Funai and some other brands.
Look on Ebay or Google the model number of the set with the word remote, remember not a universal.
Need instructions for codes for jumbo remote for symphonic tv with vcr
Hello
Setup code for Symphonic TV/VCR with Jumbo remote control is: [002].
There is no setup codes for TV/VCR combo with RCA RCU600M remote control. OK.
Sirs and mesdames: I have a Symphonic TV/VCR COMBO model # TVCRI3E1. The remote control part # (UREMT32SR007) is missing. Where can I find a replacement? Thanks, Ilia Rivera
Hello
Just buy one Philips Universal Remote control Model number [CL 034]. You can synchronise it with your Symphonic Combo by entering one amoung the following codes. Proceedings are also given.
Note: Switch OFF and Switch On your combo, before entering each code.
Three digit codes for Symphonic are:-
033/ 053/ 189
Four digit code for Symphonic TV/VCR combo is:-
0227
Four digit remote codes for Symphonic tv are:-
0053 0189 0227 0456 0024
Four digit codes for Funai are:-
0051 0189 0053 0227 0456 0042
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
You can also check according to the catelogue of that remote control also. The above given numbers are most common for all universal remote controls. OK.
What is the code for DISH Network remote on a Symphonic SC313E 13 in. TV/VCR Combo?
I hope that after all this time, you were able to find that code. But if you weren't, or you still have some questions, here are some steps and codes.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
733
632
694
Becki Barned
DISH Network Customer Service
I hope that you have found the code already, but if not, I am here to help!!! Follow the link below, which will walk you through programing the DISH remote to that tv. Very simple process!!!!
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Becki Barned
3helpful
2answers
I need the code to reprogram my Symphonic tv/dvd/vcr with a GE Universal Remote 24944
Symphonic tv codes are 0053 0189 0227 0456 0024
tv/dvd combos 0456
dvd/vcr combo 0456 {0458 & 0227}
{0899 & 0236}
hope this helps if not i can scan the code list for you
Programming cable channels for emerson tv vcr dvd combo
To see RCA's code list you probably need their website but Emerson is one of several names now owned and built by Funai, who also builds Symphonic & Sylvania.
You might want to try those codes with your set.
Please help!!!
Try the remote's "search" feature. If that does not work, then the remote doesn't have a code for that unit.
Hope that fixed ya...
Geno
Top Universal Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ADMIN Eric
ADMIN Eric
Are you an Universal Audio Player and Recorder Expert? Answer questions, earn points and help others
