2008 model
SOURCE: MY HTC DIAMOND IS IN CHINESE
go the system seting 设置/电话设置 then find language setting=语言 see if you see a word english, if you only see 中文 or 中文简体...........i have nothing to do about it, unless relfash the rom of the wm6.1
SOURCE: HTC Touch Diamond In Italian, I Want English!!!
Go to HTC's website and go to support and select htc touch diamond (make sure its 'diamond' and not 'htc touch'!) and see if there are any rom updates (in english). Make sure it is for your phone + carrier/cell provider, as sometimes there are different rom versions, for different carriers. (depends on your country, so change the country)
SOURCE: HTC Diamond touch screen phone
you'll be need to flash an WWE (World Wide English) ROM image to your device, since it went out from factory with a spanish operating system.
if you want, I can teach you how to do that.
SOURCE: how do I change my HTC Diamond windows mobile 6.1
did you try going to> start>settings>system>regional settings. then select region and reboot phone
SOURCE: change language ,send pictures via bluetooth on touch diamond 2
In order to send pictures from your phone to other devices via Bluetooth, the following steps should be taken:
• Access your phones picture library
• View the picture you want to send
• Hit the menu button
• Select “Copy” from the menu list
• Chose “Bluetooth”
• Hit “Yes” when it asks you if you want to temporarily turn on Bluetooth
• Select “Look For Devices”
• Once your phone finds the device and lists its name, you select that device name
• The receiving device is then prompted to accept/reject my file
• Once accepted, the picture is sent (takes about two seconds)
