Air Tools & Compressors Logo
I KC Posted on Feb 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for instruction manual for Campbell Hausfeld 5 in 1 cordless PowerPal
Looking for nstruction manual
Repair Ahjoshe
Level 3:
  • Campbell Hau... Master 885 Answers
  • Posted on Feb 02, 2012
Repair Ahjoshe
Level 3:
Answers
885
Questions
0
Helped
642319
Points
2112
Go to the Campbell Haousfeld home page (http://www.chpower.com/) and under the Sservice & Support tab select Manual/Parts List. Put IB200100AV in the Find Model box and hit search. If your model number on the compressor is different use that. You will then be able to download the manual and parts list.
5 Related Answers
Anonymous
  • 150 Answers
  • Posted on Feb 06, 2011
SOURCE: My Campbell Hausfeld compressor model
TAKE THE COVER OF THE TOP HAS 2 PHILLIPS SCREWS AND SNAPS OFF. THERE IS A COPPER TUBE THAT GOES BETWEEN THE COMPRESSOR HEAD AND THE CHECK VALVE TAKE THE TUBE COMPRESSION NUTS LOOSE AND REMOVE THE TUBE. CHECK THE RUBBER SEALS IF THEY ARE MISSING OR TORN YOUR COMPRESSOR LEAKS WHEN IT IS RUNNING BUT IF YOU SHUT IT OF THERE IS NO AIR IN THE PIPE SO CHECKING IT WITH IT OF WONT DETECT THE LEAK. MY COMPRESSOR WAS DOING THE SAME THING AN THIS FIXED IT.
Anonymous
  • 70 Answers
  • Posted on Jan 09, 2009
SOURCE: Campbell Hausfeld Air Compressor won't start
try turning the switch off for 5 minutes the turn it back on there is usually a circuit breaker or thermal overload that can trip let me know if problem still exists
Anonymous
  • 8 Answers
  • Posted on Mar 15, 2009
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
fredericksim
  • 98 Answers
  • Posted on Jul 22, 2009
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Anonymous
  • 73 Answers
  • Posted on Oct 17, 2009
SOURCE: Campbell Hausfeld extreme duty 4 gallon air
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
Looking for campbell hausfeld airless spray gun ps220a 2/3 hp operators manual Please!
Go to the Campbell-Hausfeld website at http://www.chpower.com/, under the 'Service & Support" tab select 'Manuals/Parts Lists. Do a search for your model number and you'll be presented with the manuals and parts lists for that line of paint sprayers.
Campbell Hausfeld manual CC2300 cant find it!
This is the site for CH products. Just enter your model number and you will be able to pick yours. Parts are also available.
http://www.chpower.com/manualsearch/
1helpful
Husky Manual for TF291201AJ
Go to http://www.chpower.com/manualsearch/ (its the Campbell-Hausfeld website) and put TF2912 in the 'Find Model' search box and you'll get the operating instructions, parts lists and other information on your compressor.
1helpful
I have a Campble Hausfeld DK705000AV cordless air compressor that will not charge. Is there any place that I can get parts for it.
If you are having trouble getting a replacement part through Campbell Hausfeld, recommend opening the case, removing the battery and searching for a part # on the battery itself. It may be a generic battery, and possibly can be found without difficulty.
1helpful
How do I get an instruction manual?
Try Googling: instruction manual Campbell Hausfeld CC2300 12V RCH Air Compressor
Replace AC charger for Campbell Hausfeld CC2300 Cordless Compress
After opening the unit up, this info I found out about the rechargeable battery.
*GS Rechargeable Lead-acid Battery (Portalac) PE12V7A (12v 7Ah) - sealed lead battery*
I hope that info help you, or someone, if you got a 12v 7AMP tip positive DC wall adapter, that thearadacly(sp?) will charge the battery, but I'm doing guess work since I don't know much about the AMP in voltage stuff.
I tried my best.
Power supply
I have been told that there official site you can buy another AC adapter, the product number 'SV99400AV' is what your looking for on there site and is also made by Campbell Hausfeld.
But I just looked, and I can't find it on there site, but I hope this information helps somehow at least.
Top Campbell Hausfeld Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
ZJ Limited
ZJ Limited
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
