I am unable to install my embroidery program so I can use it. I need to connect the dongle switch into an adaptor and be able to plug it into my laptop computer. I need to know the model number and or product number and make. This is for Designer 1 Professional Computer program that was put out between 2003-2005.
SOURCE: Dongle issue
The Designer SE software does not use a dongle. If you are attempting a "Smart Update" on the Designer SE and it asks if you use a dongle, just say no and the update on the machine will run.
If you have 3D or 4D software, it uses the dongle and it will be USB. Download the latest driver for your software from the Husqvarna Viking website. The link is through the homepage at Husqvarnaviking.com/us . Click links on the left side of the screen for 4D Software, Help & Updates, and Other Useful Software at the bottom of the page. This will have the latest 3D driver. 4D will require the latest update to the software and a firmware upgrade to the dongle. Run Smart Update on the software and then get the firmware update that is directly below the 3D HASP driver on the Other Useful Software page.
SOURCE: Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
SOURCE: dongle
I believe that the information that you have been given is correct. The VIP dongle is no longer available.
As for the second part of the question, do you have a damaged dongle or has it been lost completely? If it has been lost, there is no way to replace it without buying a new software package.
SOURCE: Can't get computer and embroidery machine to connect.
If your using Windows Vista, you have to have the multi user account in the off postioin. Also if you had 3D embroidery software and you upgraded to 4D software you have to be sure to uninstall the 32 bit drivers from the 3d for the 4d to work properly.
You do have to install the communication software that came with the diamond also. It won't communicate through the 3d or 4d only.
SOURCE: unable to load 3d embroidery on hp windows 7
3D was intended to be used on XP and also worked for some time on Vista with the proper manipulation of updates. I don't believe that it will work at all on Windows 7.
4D does work on both Vista and Windows 7. It does need the latest update for Windows 7.
