GoPro Go Pro GoPro HD Helmet Hero Video/Still Digital Camera & Waterproof Housing with (2) Batteries + Case + Acc... Case, Lens Cap Logo
robert henderson Posted on Feb 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sdhc card shows a 'locked' icon when i put it into my gopro 2 recorder
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,001 Answers
  • Posted on Dec 05, 2016
wwlvictoria
Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603833
Points
6027
Chornic GoPro 9-in-1 Accessories
  • Compatible with ALL HERO4,HERO3+, HERO3, HERO2,and HERO Original Cameras;
  • Windshield Suction Cup Mount + Tripod Adapter + Long Screw. The windshield suction cup mount hold the GoPro steady,easy to attach and remove;
  • Floating Handle Grip + Long Screw. Floating handle grip is designed to keep your camera with a waterproof shell (not included)easy to float on the water. Bright yellow in the water and can easily be found.Bike Handlebar Holder Mount+ Long Screw;
Chornic GoPro 9 in 1 Accessories Kits for GoPro4 1 2 3 Chest Strap Mount...
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Master 102,366 Answers
  • Posted on Feb 01, 2012
Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10440523
Points
622693
SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1helpful
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
2helpful
Olympus T-100, write protect shows on the screen & won't operate ??
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 09, 2012 • Cameras
Everytime i put my camrea on it says ''wright project'' how can i get it off
You declined to specify what model Olympus camera, so I'm assuming it uses SD/SDHC cards. I'm also assuming it actually says "write protect."
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Memory card locked
You didn't specify the make and model of your camera, so I'm going to assume it uses SD/SDHC cards.
Feb 07, 2012 • Cameras
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
1helpful
Hello! when i press the shutter button, it makes 3 beeps and doesnt take any video or photo even if there's enough place. what can i do?
I found out that my GoPro was saving data on the card that was not in any file. If you have lost data, when the camera runs for a while and the PIC file shows zero K, then when you delete the file, the random data stays. I got the first few minutes of a couple of sessions, then the camera shut down. Put your card in a card reader on the computer and right-click and check the card for usable space. You might find that it's full of random data not assigned to any file. Then you have to reformat the card to clear it. Just deleting any PIC files so it says 'no files found' doesn't mean the card is cleared.
If the card has space, you have some other problem, sorry. But I regularly reformat the cards just to make sure they are clear after deleting files. The GoPro doesn't care, it just thinks it's a new card and inserts it's file routine.
GoPro HD 960. The camera locks up after recording 5 to 7 minutes of video. Am able to record numerous short length recordings but if I let it run the longest I've gotten is 7:38m. Tested in the case, out...
Hi I found this:- Record up to 2.5 hours on a single charge and up to 9 hours total on a 32GB SD card (not included). Can you try another card, is the card correctly formatted is it a duff card.
Look up the user guide and that should help.
David
Just got it dont how to set it up and cant get videomode or to turn off or on is my sd 8 card shot
Do you mean 8GB SD card? There are no 8GB SD cards. Any card that size is an SDHC (High Capacity) card.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC cards. SDHC is not backwards compatible.
1helpful
For my first generation GoPro camera, do I need a memory card with a class rating higher than a 2 to have better quality videos. Also my camera seems to have a mind of its own and shuts down after about 30...
A Class 6 memory card is required for recording HD quality video. Not sure if yours is HD or not. Anything lower than Class 6 (such as Class 4 or Class 2) will result in recording issues and possibly skipping some video here & there.
As for the 30 seconds of filming limit...
1) It may be the memory card...that is if it's lower than Class 6. As a rule of thumb, when it doubt, buy Class 6 or better. Class 10 is the next step up, but it's a quite a bit more expensive.
2) Make sure you are using good, Lithium batteries...not Alkaline. Alkaline batteries will shut the camera down after a very short period.
Here are more tips on shortened recordings from GoPro's Website, followed by their Support Contact Info:
The batteries do not last very long.
  • It is not recommended that you use Alkaline batteries. Lithium batteries have the best results and longest battery life. Rechargeable NiMH are another option in mild weather.
  • Is it cold out? Battery life can definitely be affected by the cold! Please make sure you only use Energizer Lithium batteries in the cold, as any other battery type will perform poorly. In cold temps, you can expect about half of the normal run time when using the Energizer Lithium batteries.
  • Still having shortened records with a good set of the recommended batteries? Please email our support team through http://gopro.com/support for further assistance.
http://www.gopro.com/support
I only get 2minutes of video time after adding a 8GB SDHC card
There is small button on the card which needs to be unlocked so that the card is ready for recording. Also make sure you have changed the media from internal memory to Card in the settings section.
Thanks
Jan 25, 2009 • Cameras
Top GoPro Cameras Experts
 Mikey
Mikey
Tony Parsons
Tony Parsons
Vinho Xie
Vinho Xie
Are you a GoPro Camera Expert? Answer questions, earn points and help others
