When i do the " can you run it " test it shows me that my computer spec pass except one which is the video card it tell me : Video Card Minimum: 256 MB DirectX® 9.0c-compliant video card with Shader Model 3.0 or higher (ATI Radeon HD 2000 / HD 3000 / HD 4000 / HD 5000 / HD 6000 series or NVIDIA GeForce 8 / 9 / GT 200 / GT 400 / GT 500 series) You Have: Intel(R) G41 Express Chipset Upgrade Suggested: Unfortunately, your Video Card does not meet this requirement. Click here to see some recommendations. Click here for the latest Video drivers. Features: Minimum attributes of your Video Card Required You Have Video RAM 256 MB 814.2 MB Pixel Shader version 3.0 4.0 Vertex Shader version 3.0 4.0 , and this makes y computer fail . however i played the game which was extremely slow even after i put the graphics to the lowest levels. thank you for helping...
Sounds like your computer has an integrated video card and the game is looking for an extended graphics card. This type of card plugs into the motherboard via the AGP, PCI, or PCIE slots. Depending on the type of video card and computer, you may need to upgrade the power supply when you put the card in. If this is a laptop there is no good way to upgrade the video card.
Hope this was helpful
Testimonial: "it's a pc not a laptop i didn't get you very well , do you mean that the solution for making the game go faster and upgrading the video card is upgrading the power supply ? , if it's right , how can i upgrade it ? . thank you"
On a laptop you really have no way to upgrade either. This is one reason laptops do not make good gaming platforms. On a desktop when you upgrade the video card you need to check the power supply, since you are pulling more watts.
can you name me some video cards that works on my motherboard?
thank you
If the computer is a name brand like HP, Compaq; I need the brand/model number. If its a home built system I need the motherboard brand and model number. This will let me look up the information on the system and make some recomendations.
04/15/2010-G41-ICH7-6A79PG03C-00
A Gigabyte Motherboard.
I fogot to mention it's a home built computer
ok got all your information now I can make some gerneral recomendations. Most of your new graphic cards will have more than the 256 recomended memory on them. First you will need a PCI-Express card. when you go to the store ask for that type of card. I am not going to get into a discussion on here with everyone about what is better Radeon or GeForce. Either will be a massive improvement to what you have.
The only issue here for you may be cost. 512 meg cards will be cheaper, but you will need to upgrade those again sooner (due to games using more and more). For a bit over $100 you can get a decent 1 gig video card (either GeForce or Radeon).
Check your power supply, I would suggest it be at least a 500watt. This leaves pleanty of breathing room for the video card, hardrive, motherboard, processor, DVD drives, and some expantion.
Just remember on the video card it has to be at least 256 meg of memory and a GeForce or Radeon type card and a PCI-Express slot type.
Good luck and let me know if you need anything else.
thanks alot , your information ware very helpful , thank you and good by.
SOURCE: the vga memory in gigabyte
I have g41compo - ram 2 giga - prose cor2duo e7500 2.98 - 3cash
and gta iv not open why?
can any one help me!
SOURCE: how to overclock foxconn g41 mxe motherboard?i
ur overclocking depends on ur memory if u computer takes max mem, of 8 gig do 10 memory overclocking is much safer than over clocking mhz
SOURCE: biostar g41-m7 motherboard troubleshoot. I get no
*********** board was damage, change it with new one with same specification
