Question about Konica Minolta PRINTING - Bizhub-250 Minolta 25ppm Printer/Copier/Scanner/Fa
What does error code 0x00009a mean on bizhub machine
4 Suggested Answers
6ya staff
SOURCE:
steven brickhouse
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
Anonymous
  • 214 Answers
SOURCE: Error code C-D351 on a Bizhub C250
are you sure that you have a correct model and malfunction ccode ??? i cant find this code on bizhub C250
Posted on May 11, 2008
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
Bizhub 600 - error code 47-07 mean?
C 4704 is a Laser error code. I would turn off the machine by the main switch located in the front door. Unplug the machine for 10-15 seconds then reconnect and turn on. If the code comes back you may need to call a service technician
Apr 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta bizhub c 351 code c 3451
this error code means the fuser rollers failed to heat up you can reset the code by turning the machine off and hold down the utility\counter key while you turn the machine onwhen the trouble reset button shows on the touchscreen touch it and when it says ok turn the machine off then back on if the machine gives this erro again you will have to have the fuser replaced
Nov 19, 2009 | Konica Minolta bizhub C351 All-In-One...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
My bizhub 210 is coming up with an error mesage which says ,"CAUTION, MACHINE TROUBLE, SERVICE CALL COF32" Please may you asist me
its the code of ATDC sensor, that means your machine is having low deveolper, kindly change the developer to permanently get rid of this code. thanx
Nov 10, 2009 | Konica Minolta bizhub 180 All-In-One...
C03FF Minolta bizhub 210
C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
Jan 29, 2009 | Konica Minolta DiALTA Di183F Copier
Bizhub 350 error code
Apr 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub 350 Error code c0211
It means Bypass Lifting Motion Failure, check pick-up solenoid and lift up sensor.
Reboot machine holding down utility button, then do trouble reset, if nessesary reboot again.
If this error occurs again, you have to call for service
Aug 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
193 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
