SOURCE: I need to find the pattern for the serpentine belt on my 2002 toyota echo
Did you check under the hood? There should be a decal w/ the proper routing of the belt somewhere in or around the engine compartment. If u can't find it, let me know, I'll try to get more info. countrycurt0
SOURCE: Plug replacement on a 2005 Toyota Echo 4 cyl engine
Hey alanacheson,
The spark plugs are underneath that cover on top of the engine (should say VVTi on the cover).
Just take that cover off, and then you will see the four ignition coils. Take off the four ignition coils (with igniters), and you will see the four relatively long holes underneath, and the spark plugs are at the bottom of those holes. You will need a good spark plug socket (preferably a thin wall socket) and a 6" or 12" extension. This is actually a very easy job, and can be completed in less than an hour.
Hope this helps.
SOURCE: 2002 toyota echo
Either the sensor on the air filter needs to be cleaned. Easy. I've done it myself. Or one of the sensors, before and after the catalytic converter, needs to be changed. difficult.
SOURCE: Suddenly my toyota echo 2002 battery light come
check the alternator fuse and main breakers if they are okay look to see if any belts broke on the engine if they check out okay then replace the alternator
