Your computer is connected to the router. check the port lights on the router. If your computer is connected to number 1 port on the router then you will see port 1 light on the router.
Connect your computer to one of port 1, 2, 3, or 4. Not to the Internet port.
If the port light is not lit up then check the connections. Make sure that there is no loose connection.
If ti is lit up then check the IP address on your computer. The default gateway number wil be the IP address of the router. Use that number to access the rotuer settings. Some times the Ip address of the router will be different ( Depends on ISP ).
Once you have correct I address of the router then try to ping that number and check if you get replies.
Click here for more information abotu router and networking
