Need to scan muliple pages and they are all coming out in separate pages in the PDF format I need them all in one document and I dont have an auto feed system
SOURCE: Lexmark X7350 Scan feature
well you are able to scan multiple documents.. but the file size is more.. the way lexmark software writes the pdf file.. the file will be huge for PDF... but not sure if this is a case with any other all in one manufacturer like HP also... but i would assume it would be the same.. so scan the file to MS WORD or any other application that supports multiple pages... so u have it as one file... but if u want only pdf files, then u have to do a little work around like writing the MS WORD Document to pdf format. If the PDF Writer is not installed with your copy of MSWORD then try any free pdf writer software available on the internet.
SOURCE: ocr folder
The software you need is Abbyy Sprint OCR. If it's not installed, I suggest running the printer setup again, making sure it's selected when you get to the software list. Perhaps you unchecked the box when you ran the installation the first time, or didn't know what it was and uninstalled it from your computer. You may be able to find it by hunting through the CD, but it will probably be easier to run the setup again.
SOURCE: lexmark x4650 AIO, will only print first page of multiple pg doc
In this case what i would Request u to do is......... Goto Control Panel goto Printers folder......... There u will see the Lexmark Printer Icon........... Just right click on the Printer Icon and click on Properties......... Now click on Advanced and goto Print Processor......... Change it to Lexmark X1100 and NTEMF 1.0008........ Click on Apply click Ok now try to Print.......... Prints Fine............Issue Resolved........
SOURCE: how to find the PIN number to scan for a Lexmark
Unless you have setup a PIN for scanning when you installed the printer the default PIN is 0000. If you setup a pin and don't remember, go to the Lexmark Productivity Studio, click on setup and diagnose printer, then on left side select Advanced, another screen will pop up click on Networking and another screen will appaer at the bottom there is a link that reads Change your PC name and PIN for network scanning, click there and you should be able to see and/or change the PIN.
Good Luck and don't forget to rate this answer.
