When I switch on this monitor it switches it self right off any idea what it could be or where I can get a circuit diagram from any help will be greatly appreciated
It sounds like defective capacitors in the power supply/inverter.
Unless you are experienced in electronics be careful repairing.
Check for bulging electrolytic capacitors, bulging capacitors indicates they are defective. But a bad capacitor doesn't always bulge to indicte it has failed. Replace all cheap capxon capacitors, with low ESR rated capacitors from Digi-Key, Mouser, Allied electronics or Newak electronics.
SOURCE: Monitor says No input signal and going to sleep.
Try cleaning your RAM it should be the issue mostly 80%
You can check by rremoving the VGA cable if the system shows no signal mostly monitor should be fine
