SOURCE: Horizontal pink & blue lines across color pictures that I print.
In the past when I have seen this on my old printers, it is the color cartridge. Eithe the haed is cloged or it needs to be replaced. You could try to take the color cartridge and set the print head(copper colored end) on a damp towel for a little while and see if it will release the clog. (HP uses mostly water base inks and they dry out sometimes) Then wipe the head on a dry cloth. Reinstall and try again. You should also have software for HP to prime the head and clean it. Try that and if you still have problem, replace color cartridge.
SOURCE: printing with a black horizontal line across bottom of the page
Wipe the cartridge.Use cotton but dont put water on it only cotton.if you have deiones water its good to use.
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue
The Out of Paper
message appears on the computer and the product stops picking up or feeding paper.
Solution
Step one: Reset the product
Step two: Check the condition of the paper and reload it
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
NOTE:
Do not load too much paper in the product.
Step four: Clean the rollers
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
CauseAny of the following issues can cause the error message to appear:
SOURCE: HP 6500 cuts off last line. Help
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3795314&lang=en
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
