Ime 358849009981653
Http://www.unlockme.co.uk/master.php
How to Unlock Your Nokia Cell Phone
Typically when you purchase a
cell phone, the company that sold you the phone 'locked' the phone
before you bought it, so you can only use it on their network. This
means that you can't use your phone on any other network, even if you
change the SIM (which is an abbreviation for Subscriber Identity
Module) card. The SIM card is the little piece of plastic that
identifies your phone to the cellular network. Changing your SIM card
to have your phone work on another network is useful especially if you
want to travel to another country and want to buy a pre-paid SIM card
so you can have cell phone access without roaming charges. There are
services that offer to provide unlocking capabilities for a fee, but
don't pay for them! You can do it yourself for free, which is the
perfect price.
Steps
1. Before trying
anything else, contact your service provider and ask for an unlock
code. Usually, if you've been a customer of theirs for some time, they
will provide you with an unlock code for free. This is, by far, the
best way to get your phone unlocked.
2. Download software to
generate the unlocking code. Software is available on some websites for
free and some pay websites that also offer support if things go wrong.
See external links below.
3. Find the Serial number of the cell
phone, also known as your IMEI number. This can be done by either
removing the back of your cell phone and looking underneath the
battery, or simply by typing in *#06# into your cell phone. It should
be something like: 030057361439976/05429508118
4. Using the
software you have downloaded, enter in your Manufacturer (which is in
this case Nokia), your model number, and your IMEI number. Also enter
your country and the Network. Calculate the code, this may be different
depending on which software you are using. If your phone is the Nokia
3390 phone, select the model 3310, they are the same phone.
* #pw+403927744443466+7#
5. Remove the SIM card from your Nokia phone. This is typically done
by removing the back cover of the phone and removing the battery and
sliding the card out. Put the battery back in and power the phone on.
6. You will see a message "Insert SIM Card". Enter all of the
characters you see in your code, including the # symbols. To get a 'p'
press * 3 times, to get a '+' press the * key 2 times, to get a 'w'
press the * key 4 times. Disregard any spaces in the code.
7. In
order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the
first code (MCC+MNC), use code "7" (Multilock)
8. Once you have
finished entering a code that works you should see a message that says
"SIM is not restricted" or "Restriction off" message depending on your
model. If not, try entering another code. Message "Cannot undo
restrictions" means the phone is "hard-locked" and cannot be unlocked
by code.
Tips
* Unlocking only
applies to GSM phones, phones using other cellular technologies, cannot
be unlocked without special software and hardware.
* Switch off
the phone. Hold the keys "3", "*" and "Call" and switch the phone on.
Keep the buttons held down till you see the word "Formatting..." on the
screen. Make sure that the battery is full charged before you attempt
this. This should reset the phone lock code.
Warnings
* Attempting to unlock your phone is done at your own risk. Although
unlocking your phone is legal, some cell phone operators might choose
to void your warranty should you unlock your phone (then again, some
cell phone operators won't mind).
* Most phones only allow you
to try a certain number of unlock tries, Nokia phones have a limit of 5
tries. After that, the phone becomes "hard-locked", meaning it cannot
be unlocked without using special equipment.
* Most of the newer phones will not work with the codes generated by the free unlock programs.
Hi prathap..
Refer this link and your master code is...
http://www.unlockme.co.uk/securitynew.html
I forget my password
nokia 1100
imei 35568900/169204/6
code; 0512345
type RH-18
I m Forgot my
security code for
Nokia 1100 imei is 353378009923270
Nokia forget passward
SOURCE: reset my nokia 1100 Security Code
Hi..you have to visit a mobile service centre .shop and he will do a master reset in 2 minutes using a particular software No need to flash the phone, however you will loose all your numbers stored on your phone..
thank u
i have forgotten my secuirity code for my phone nokia 1100 can you please assist me with either resetting it or maybe a mastercode?
i have forgoten my phone security code i want to know how can i solve my problome
foget my security code
I have a Nokia 1100 and I lost the security code, now I got the master code but I don't know how to use this code in order to unlock my fone.. can u plz help me out.. I want to break the security code by my self.
please help me
my IMEI number is 353754004835117
i orgot my phones security code
NOT ACCCEPT SIMS
master unlock code
Please describe the specifics of your problem below. We'll add your post as a comment to vishnu2010's "reset my nokia 1100 Security Code" problem, and notify you when a new solution is offered
i have 1108 noki PHONE I forget the my password so pls give me imei no. 357592003270225
trhanks
Your IMEI: 358379006004309 --
reset my nokia 1100 Security Code" problem, and notify you when a new solution is offered my imei no35535200/782031/5
hiiiii i m sainath i have 1108 phone i forgot my password can u tell me plzzzz
my mobile no is 8722992802 i have forgoten my phone security code i want to know how can i solve my problome
i am forget my phone security code i wantto know how can i solvemy phone problem
