Sirius Satellite Radio S50-TK1 Satellite Radio Receiver with Car Kit Logo
Posted on Oct 20, 2008
Sirius S-50 Portable
Tring to change the fm frequency on the sirius S50 , can you help please?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
338
Points
Go to device settings - FM Frequencies - select the FM 1 or FM 2 or FM 3, turn the dial to move the FM frequency to that which you want. Press the Sirius Dog to enter this frequency. That's it.
I have audiovox Sirius radio from 2004 and still works fine. I am having a problem finding a frequency setting while driving from phila. Pa. To Newark de. Can you help me with a frequency setting that...
I use a wired fm modulator that the fm antenna passes through. When the sirius radio is on it blocks the regular fm signal preventing local signals from interferring. Do a search for wired fm modulator and you should find one. Mine actually fit inside the dash on my pickup.
1helpful
Sirius S50 "No channels available"
I had the exact same problem happen to me yesterday with my S50. My guess is that the software got corrupted somehow. I fixed mine last night be reinstalling S50 software via USB cable to my PC. Note: You need My Sirius Studio application loaded on your PC. Be sure to press Exit button on My Sirius Software Ap after you reinstall S/W. Patiently wait for S50 to 100% complete before disconnecting. Then, manually turn on S50 (while holding in your hand); do NOT put in car/home dock yet. S50 will then update S/W. When this completes, now you can put in dock. I don't exactly recall, but I think the S50 indicated the dock was being updated, then it defaulted to channel 184 indicating to call Sirius to subscribe. Since I already have a subscription in place on my S50, I just pressed channel 2 (The Blend) from my remote, and then my S50 began updating all channels. Success! I'm so happy my S50 is now working again! Good luck to others experiencing same problem; hope this helps! I can only imagine the frustration trying to get help from Sirius folks for this type of problem...
What fm station do i use in the car
You need to find a clear radio frequency in your area then in the SIRIUS sat radio you will find a FM transmitter frequency adjustment menu. set it to the same as your fm radio and your all set.
Acura TL XM conversion to Sirius
You can get a Windshield Mounting kit and Sirius Unit and use the FM Frequency Modualator that is Built in and just not use the XM.
1helpful
2answers
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Sirius s50....
u have to use the sirius studio software to do that
2helpful
Sirus radio
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
Sirius S50 buttons
bring back to the store broken product
1helpful
Probleme s50 usb conect pc
You have to use My Sirius Studio as the interface to your S50 to add/remove MP3 songs. Depending on your Windows version (hopefully 2000 or later) you should be able to connect via USB and Windows will autodetect the device. My Sirius Studio is a poor man's iTunes where you have to add music files before you can drag them to the playlists you created on your S50. You can download the software from the Sirius web site, including the latest update. Keep in mind you have to disconnect the S50 from My Sirius Studio. You can't copy files to it and then unplug the USB cable.
Top Sirius Satellite Radio Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
