The first problem we had was with the Freezer. All the items in the freezer would get little fuzzy ice sweaters on them. So I moved the fridge away from the wall so that it could circulate more. Then that problem seemed to go away and then the problem with the freezer and fridge not getting very cold came. The entire unit had a hard time staying could and everything defrosted in the freezer. We didn't do anything different, we thought it was because we were going through a heat wave here...but the fridge righted itself and started working without us doing anything to it. Then a few weeks later the tops of the freezer and fridge side are room temperature, but the bottoms of both are good cold temperatures.
On the bottom of the unit the fan is working and the compressor is very hot to the touch and it's making noise so I'm guessing it's working.
Inside the freezer there is frost on all of the coils, but the fan is not working. Is there something I can replace myself to get this working again?
Thank you!
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Thank you! I checked the fan and it plastic coupler that connects wiring of the fan was actually not fully pushed together! don't ask me how this happened, somebody must have done work on the fridge before and didn't connect it thoroughly.
Thanks again =)
Lil Fixer
Thanks again =)
Lil Fixer
Hi Again,
So the original problem has come back.
Everything gets cold enough now, but the problem of the Fuzzy Ice Sweaters on all of the food in the freezer is starting to come back. Actually it's just the top couple of shelves right now.
Do you have any ideas on what could be causing this? I'm guessing it's some sort of moisture...any ideas?
Thank you,
Lil Fixer
I am Having the Same Problem on my Kitchenaid Model KSRG25FRSS16
