The hold button on the top of my mp3 walkman has slipped slightly inside the machine so I can't turn the hold off. Is there anything I can do to right this problem?
Silly girl tells it all use the ON button and make sure u turn it back OFF mabey it doesn't turn on by itself mabey you just don't turn it off.
Is there a space in the line between the back and front panels of the player, or is it seemless? If there's a slight crack, take a sharp regular screwdriver(not the philips kind, the other one, flat), hold the player with the eject button facing down, open the crack a little more with the screwdriver on the side of the player, and tap the button area, try to make it full back into place. If it does, just try to close it shut so it's seemless. If it's seemless, you could still try poking at it with a thin metal object(not something that is likely to break and leave pieces inside), but if you're worried about it you could take it to a shop that deals with things like this. Sometimes they wont even charge you if it's a 2 minute fiddling thing. Good luck, I'm curious to know how you work it out so comment back here!
SOURCE: i need help adding music to my sony walkman
it's the 4GB NWZ-A816PNK Walkman version?
connect usb to your computer
wait for the connect sound
open my computer
look for removeable drive
right click on it and explore
go to music folder
open your library
drag w/e songs u want into the music folder
dc, turn on. browse and play. hope this helps.
SOURCE: My Sony Walkman MP3 player just simply won't turn on!?!?!?!
I've the problem as well. Did you find out any solution? The button is like dead but the screen is on when i plug it in my PC.
