The problem with my TV is that the red led stays on after turning off the TV. The TV comes back on and every thing works just fine. I've tried to unplug the set for awhile then plugging it back in and the red led came on. I turned it on and off and the led still is on. Any ideas?
Check relay s901 in power supply. It sometimes can be stuck in the closed position causing the symptom you describe.
Aren't you talking about the standby led? cause that is perfectly normal... when it's on it means you can turn the TV on by remote, usualy it goes away when you turn the TV off manualy by pressing the OFF button on the set, but is this really your problem?
