After you execute a command (=) and have the result displayed, you can press the Left Arrow of the Replay button to move the cursor to the end of the last command line.Use Left arrow/Right arrow to move cursor along the line and modify it (change a value, operation sign, etc.) After you make the changes press the = sign to execute the modified command.
SOURCE: casio fx-82ES scientific calculator
change the mode to stat and then start operating it in statistical mode
SOURCE: how to use the cosine,tangent etc functions of
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
SOURCE: Convert to Binary in Casio fx-82ES
dear kladofora thire is no 4:BASE-N in the mode please i need help Gist
SOURCE: casio fx-82es significant figures
it should...
it can be found by SHIFT then MODE then SCI is the one you want to choose
