SOURCE: uniden 6.0 with 2 handsets
Unplugged all telephones but one and still had trouble so I called Verizon. They discovered it was an incoming line that was malfunctioning. However, the Uniden telephone system still does not work and since it is still under warranty I will contact them.
To continue the solution of my telephone problem - It was discovered that the incoming line was indis repair. After it was repaired, I again set up my Uniden telephone system. It works with no problem. The word "searching"still appears on the face of the units, but it can be overcome with normal activity on the units.
SOURCE: two sets Uniden phones with base, second handset: incompatible?
I had the same problem with a Uniden 3355 handset and 2355 base. With the new handset I pressed "Menu" and selected "System Reset". I then Selected "Deregister HS" and followed the prompts.
Once this was complete, I returned to "System Reset" and selected "Replacing Base". Following the prompts, when it said "Register Handset" I put it in the base of the 2355, and within a minute it had registered, so both handsets used the base of the 2355!
S.
SOURCE: can not able to answer any incoming call
if you suspect the problem is with your device, then reset the phone by following the instructions given in the instruction book which came along with your phone..if it still doesnt work then check the connectivity by connecting some other phone(friend's phone) with your landline cable.if the new phone is also not able to receive calls then contact ur service provider..but if the friend's phone works with your land line connection then pls report again
SOURCE: uniden 6.0 answer/base/ cord less message set up
Thanks for using FixYa.
Please let us know the complete model number of the phone.
