The power cable works fine, but it does not want to switch on. i can see the charge indicater is busy charging and when it is fully charged, yet no juice.The power cable works fine, but it does not want to switch on. i can see the charge indicater is busy charging and when it is fully charged, yet no juice.
You can't post conmments that contain an email address.
can you connect it to your usb port on your computer? if so try to connect and use it. dont worry about charging it just use it to see if its working ok. i dont know why they put a battery that is not replaceable in those. you must send it back to them to replace, I keep mine on power all the time. check this out first and see if its a malfunction or works ok.
The usual problem is the voice volume is turned down. This can happen when you are adjusting the volume down just as turn by turn instructions are starting; thus you don't notice it happened, or someone else did it or software glitch caused it or Murphy's law. The way to fix it is turn vol up to max and set navigation and start driving. As you get to navigation points where you would expect the turn by turn instructions hit the up volume button. Keep trying it will only go up whilst instructions are being broadcast. Try using repeat last directions function to get a better shot at it. This happened to me and this was the fix, odd but true. Also see if there is a turn by turn vol level in settings. Hope it works for you.
I HAVE A 2100 NAVIGON GPS SCREEN WONT COME ON TRYED CHARGEING IT THE ORANGE LITE COMES ON /WONT CHANGE TO GREEN ALSO TRYED TO RESET NOTHING DO YOU HAVE ANY IDEAS WHAT ISHOULD DO NEXT .
Wiring diagram pinout for Navigon GPS charge and concurrent use
Pin
Pin Name
Description
+5V
5 Volts Direct Current
Data
floating/Not connected
Data
X
Ident
Conneted to Pin 4 (GND) as pure short, no resistor
Ground
Ground, shorted to pin "X"
Use of standard mini-b will place unit in
Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short
will allow use of Navigation software and concurrent charging. USB power
source must be 1000 ma or above.
I had a similar problem with my 2100Max. I took the SD card out, plug it into my computer and then reinstall it. It works like a charm these last months still.
