I was in hospital next to the machinary and my phone screen went white, since it now how vertical purple lines down it and occassionaly half of the screen display appears then goes green/black then back to white again, i was wondering if it could be the electrical equipment that has had an effect on my phone of something else?
Hello, friend! I happened to see you with this problem, I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional repair tools.
They are free to consult, I hope that the programmers I recommend can help you.
SOURCE: something recently dropped on my
I have had a similar problem with one of my phones and called the phone company right away. They suggested that I take out the battery for about 1 minute then put it back in and try starting the phone up again. It is also possible that some of the connectors on the LCD have cracked (making the white lines appear). Try the first suggestion otherwise if your phone is under warranty I'm sure they will fix it (don't tell them you dropped something on it just say it was in your pocket or something mundane like that). Also make sure not to open the phone because that my hinder the warranty. Good luck!
It's a good chance that the drop may have broken the connection from the board to the LCD, or cracked some of the connectors on the LCD itself as they are tiny pieces of glass and plastic... I believe that replacing the screen would do it, although if the phone's under warranty, call the carrier up and tell them that you have lines going across the screen... they may just replace it for you. I had a few dead pixels show up on my 8530... and they sent me a new one, as there were no refurbs at the time... this was about 1o days after I bought the phone. Sent back the old one, and everything has been perfect since... Sorry can't help more, it's one of those things that unless you pull the device apart it's hard to tell... Also, you might kill your warranty if you open the phone... So it's a Catch 22 either way. Although, I would just let the pros that get paid to rip the phones apart handle it for you...
SOURCE: I have a black berry curve 8520. my screen is
Try pulling the battery while it is on, waiting at least 30secs, then put it back in. Let it boot, sometimes this works.
Otherwise, reloading the OS and resynchronizing the data should help to get your device working again.
Use the blackberry desktop manager software that came with the phone to reload the OS.
SOURCE: blank white screen on my blackberry 8520 curve from switch on
Sounds like your screen is physically broken. If your Somebody needs to open your Blackberry and replace it. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
SOURCE: My bold has a white screen with a couple black
my 9700 bold, just use 1 month only, but yesterday it suddenly no line when i messaging~~
