Have no ac output on the generator side of the welder, generator
When the generator is not used orstorage for a long time, the residual magnets contained in the iron core are lost before leaving the factory, and the excitation coil cannot establish the proper magnetic field. At this time, the engine is running normally but no electricity is generated. This phenomenon is stored in the new machine and stored in the humid. There are more units in the environment or long-term use.
SOURCE: wiring problem for a hobart G-213 welder
download it for free.
http://www.scribd.com/doc/12408431/1985-Wire-Diagram
SOURCE: Welding breaker keeps popping on my Hobart Champion 10,000.
look for short inside unit,start at breaker and work your way back.
SOURCE: I have a Hobart Champion 10,000 welder generator.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
SOURCE: I have a Hobart Champion 4500 Ac Generator/Ac
try a different plug sometimes new plugs are no good
