Its seems like you have infected with spy ware of sometype. first of all look at the task bar, I am sure there is a yellow triangle or something similar with a ! mark on it, if try to close it, it wont give you that option. So first of all, turn on windows defender download the updates and run the spyware check. IF this does not help get a antivirus/antispyware s/w and run it. Lets see how that goes.
http://www.eradicatespyware.net/How_To_Use_HijackThis.html
and scroll down to the selection that says "020 - Winlogon Nofity: Wgalogon - ..." select that, and click fix checked.
You can also go and delete the actual executable that nags you. The full path to it should be (for most installs) C:\Windows\System32\wgatray.exe.
Reboot after this. No longer should you get the popups and that nagger as you log in should not show up either
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
what kind of pc you using?
